Antnicuk
posted on 27/11/15 at 11:15 PM |
Fitting an Oil Cooler, Do i need an Oil Thermostat
A technical question for you clever people.
I am fitting an Oil cooler to a BMW M30 engine (Old E34 535i) I can get an adapter with take offs for a cooler, i just wondered if all engines running
an oil cooler also ran a thermostat. I know a lot of OEM cars run a stat within the cooler but an aftermarket cooler wont have that.
Thanks for any help and advice.
BTW, the reason i am fitting an oil cooler is i am turboing it. This will also help with a take off to feed the turbo.
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
theduck
posted on 27/11/15 at 11:24 PM |
Personally I'd run a thermostatic sandwich plate and take my oil feed from a tee with the oil pressure switch.
CosKev3
If its a road car a stat is advisable,as a cooler can over cool the oil
Obv if it's a track car etc that's going to be thrashed permanently you can do without a stat.
[Edited on 27/11/15 by CosKev3]
Antnicuk
posted on 27/11/15 at 11:32 PM |
thanks, it will be a bit of both. Ive not seen a sandwich plate for it as bmw use a cartidge type filters so not sure i can get one with a built in
stat. I have heard of issues with cold oil not being able to circulate through a cooler and causing poor pressure when cold. does it work like
that?
I was thinking of using one of these
https://www.iemotorsport.com/bmw/E34-engine/M30coolercap.html
CosKev3
posted on 27/11/15 at 11:36 PM |
You can get in line oil stats,Mocal sell them
CosKev3
posted on 27/11/15 at 11:38 PM |
https://www.google.co.uk/search?ie=UTF-8&client=ms-android-samsung&source=android-browser&q=mocal+oil+cooler+stats&gfe_rd=cr&ei=O-
lYVsmdENCDcKHGtNgC
Antnicuk
posted on 27/11/15 at 11:44 PM |
thanks for that, thats what i used to run on my rotary stylus. I will probably go with something like that again. I just wondered if it was
possible not to
theduck
posted on 27/11/15 at 11:47 PM |
Sorry was forgetting BMW use cartridge type.
cliftyhanger
posted on 28/11/15 at 07:52 AM |
I would suggest that even a track only car may need a thermostat. It will help the oil warm up faster, essential to get it working correctly with no
downside.
And then there is the option to use a oil/water heat exchanger which is even better. It warms the oil quicker, and moderates oil temps nicely. Used in
many many modern cars, and for good reason. Downside is it puts a little extra strain on the water rad, and it needs plumbing into the cooling system,
but in reality a small price to pay. In fact, there may be a suitable one from a later car? worth a look...
posted on 28/11/15 at 08:30 AM |
I think I would monitor the oil temps before fitting an oil cooler, in the UK climate even racers need the cooler at least partially taped over most
of the time.
Antnicuk
posted on 28/11/15 at 03:50 PM |
my 335i runs oil temps of 118 degress consistently on the motorway at any time of year which amazes me but this is how BMW designed it as it seem they
all do! As soon as you take one on track it goes over 125 and if they get too hot go into limp mode when it gets too hot! They have an oil cooler as
standard.
The stock E34 M5 has an oil cooler with 340 bhp so i figured as i want closer to 450 bhp i should invest in a cooler while i am rearranging the front
of the car to fit an intercooler and bigger rad.
theduck
posted on 28/11/15 at 04:04 PM |
of the time.
Surely then they are just running a cooler that's too big?
Antnicuk
posted on 28/11/15 at 06:46 PM |
of the time.
or, they need thermostats?
CosKev3
posted on 28/11/15 at 08:06 PM |
Saw oil temps knocking on the door of 150 degrees C doing 15 minute sessions at Castle combe in my VRS with just the standard modine.
