Author: Subject: MGF inlet on a Zetec???
Antnicuk
posted on 1/12/15 at 08:04 PM Reply With Quote
Evening all,
i was wondering if there were any other options for the zetec inlet other than the GTiR. I was wondering about the MG inlet from the k series. (Obviously conversion plates will be needed) I need an inlet if go forced induction on the zetec rather than an engine swap
600 BHP per ton, Stylus Brought back from the dead! Turbo Rotary Powered!
Ugg10
posted on 1/12/15 at 08:26 PM Reply With Quote
Rover t16 turbo inlet was a popular choice a while back iirc.
http://www.turbosport.co.uk/showthread.php?t=79262
http://passionford.com/forum/pictures-video-and-photoshop-forum/156163-pics-of-inlet-manifolds-on-zetec-turbos.html
[Edited on 1/12/15 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
AndyW
posted on 1/12/15 at 08:37 PM Reply With Quote
I have used THIS
Currently on n/a injection but upgrading to turbo this winter.
Antnicuk
posted on 1/12/15 at 08:42 PM Reply With Quote
Some one put a link up to these on another thread but I was hoping to keep it locost. That still needs injectors, throttle body, fuel rail and regulator. It looks like some of these oem set ups may have all I need.
posted on 1/12/15 at 08:52 PM Reply With Quote
A Rover M16 or T16 inlet fits the adaptor plates an be bought or you can make a minor mod to the head.
Turbro and mPi manifolds are the same.
K series won't work because the inlets are too closely pitched.
Ugg10
Iirc the kitspare and the pepper plenums take the stock fuel rail and injectors and throttle body. May even have a port for the idle valve if you are lucky. Or they use the injector sandwich plate on the zetec.
ali f27
posted on 2/12/15 at 12:20 PM Reply With Quote
Hi i have a te power products manifold if its any good would be cheap s i have no use for it
Ugg10
posted on 2/12/15 at 03:50 PM Reply With Quote
http://www.ferriday.co.uk/manifold-adaptors/
Ferriday do an inlet adaptor for Zetec to Rover T series if that is of any use.
posted on 2/12/15 at 04:09 PM Reply With Quote
I'm planning on using the standard plastic OEM inlet on my 350 build...
posted on 2/12/15 at 08:20 PM Reply With Quote
I have a Rover Turbo M16 manifold sitting in the sheds fuel rail but no throttle body.
Antnicuk
posted on 2/12/15 at 10:11 PM Reply With Quote
how much?
ali f27
posted on 2/12/15 at 11:19 PM Reply With Quote
50 posted if its any good cheers Ali
