roohunter
posted on 4/3/16 at 11:33 PM |
What's the best Diff for a Bec
What is the best Diff for a Bec kit car ?
daniel mason
posted on 4/3/16 at 11:56 PM |
Depends on many factors.
1; rear tyre diameter
2; engine
3:what the vehicle is used for
4:rear axle type
5: the list goes on.
As a rough rule - a 3.38-1 would suit most engines for most things on an IRS setup
A 3.54-1 on a live axle
A 3.14-1 would be OK with a hayabusa or similar if road use and big journeys were likely
A 3.21-1 freelander diff is a good unit with an Atb lsd. And light
But if a circuit based car it'll be better to gear for max rpm at the end of the longest straight your likely to do!
roohunter
posted on 5/3/16 at 08:28 AM |
Irs
Zx9 engine
Seven style car
Currently running a 3.62
What are the benefits of a 3.38
daniel mason
posted on 5/3/16 at 08:42 AM |
I had an ir's car on 185/60/14 rears and a 3.62 diff. It was slightly under geared for road use.and was pretty noisy at cruising speeds above
60mph
[Edited on 5/3/16 by daniel mason]
roohunter
posted on 5/3/16 at 08:57 AM |
Yeah this does sound noisy but the sound doesn't come from the Diff
It's running on 196-45-15S is there any acceleration or speed benefit ?
gaz_gaz
posted on 5/3/16 at 09:32 AM |
Everyone raves about fitting a 3.38 on BECs here instead of 3.62.
From my own experiance.
The car will accelerate a little slower, have a theoretical higher top speed. And at say 70mph will be reving a little less.
My old 919cc fireblade MNR would do about 115mph flat out just tapping onto the limiter but it needed about 2 miles of Swiss Alps straight road to get
there. This was with a 3.62
My old 1000cc R1 5jj with 3.62 would hit 120mph on the straight at Spa on the limiter. With a 3.38 fitted it was pretty much identical top speed but
obvs not on the limiter. It did take more of the straight to get to 120mph though.
The carbed blades and R1s just don't have enough power to pull through the wind.
The only benefit in a 3.38 I see in a 7 with 7 style body is dropping the revs 500rpm or so whilst cruising along in 6th.
My new car is full body. 2013 fireblade engined and I've still gone for a 3.62. I do have a 3.38 sitting around just in case but I'm not
convinced it'll be required
If noise and high revs bothered me I wouldn't have got a car with a bike engine :-)
[Edited on 5/3/16 by gaz_gaz]
adithorp
posted on 5/3/16 at 09:54 AM |
Have you had a lookat the speed calculator thread (top sticky in this section) ? That'll give you the relative speeds for each diff.
I'd guess the 3.62:1 is about right for that motor. Prs... Will give good acceleration. Cons... Shorter gears (more changes required).
Restricted the top speed a bit (but given the (non) aero properties of a 7 that'll be low anyway unless you have a lot mre power than the zx9).
The revs might be a bit high for motorway cruising
A 3.38:1 will improve the cons at the expence of a little accelleration (though fewer gear changes will balance that out a bit.
http://jpsc.org.uk/forum/
Wadders
posted on 5/3/16 at 11:42 AM |
On paper acceleration might be slower with a 3.14 But in reality my drag times inc 0-60 dropped quite a bit when I ditched the 3.62
Less wheelspin off the line and you can hold the gears longer.
Makes no difference to setting off either, so definitely better.
This is with a ZX9 engine and 13" wheels.
70mph is approx 7000rpm in top gear.
ArthurR
posted on 5/3/16 at 01:17 PM |
An Elite MX200.
Built in reverse
Can change the ratio in about 10 minutes simply by taking off a cover and changing two gears.
And I happen to have one that I was just about to post for sale ![](/images//smilies/smile.gif)
ian locostzx9rc2
posted on 5/3/16 at 01:34 PM |
I had a zx9 in my striker I built many years ago had a3.64 diff it used to rev out in top 12 k and that was 120mph genuine speed I was running
185/60/14 tyres so it was 10mph per 1000rpm I think I did a quick check and a 3.38 diff would give you 11mph per 1000 revs in top gear
