evo97
posted on 4/7/18 at 12:18 PM |
self cancelling indicator unit
as above anything available ideally the westfield unit
Charlie_Zetec
posted on 4/7/18 at 01:45 PM |
THIS is the sort of thing you're looking for, for
use with non-latching push-button switches.
evo97
posted on 4/7/18 at 02:48 PM |
Yep don’t want to pay £100 tho 👍
Bunje
posted on 4/7/18 at 03:33 PM |
http://blinkstop.co.uk/shop/index.php?route=common/home
try here the guy that makes them is a member on the wscc forum and its a top quality bit of kit i have his wirless steering wheel package
evo97
posted on 4/7/18 at 03:37 PM |
Yep I have seen them but my soldering skills are shocking so will have to go for a built unit at £65 then a new non latching switch which is close to
what Westfield sell the complete kit at £85.
Was hoping there was a used one around 👍
peter030371
posted on 4/7/18 at 08:45 PM |
You can get the Signal Dynamics on eBay for just over £60 delivered. Easy to use and works OK for me
Dave Bailey
posted on 4/7/18 at 09:04 PM |
Is it a Sierra steering column? Can you use the original switch and mechanical cancel with the plastic collar? This is how I have done it...
Dave B
evo97
posted on 5/7/18 at 10:45 AM |
Currently using a toggle switch on dashboard
kingster996
posted on 5/7/18 at 09:40 PM |
I have one you can have for £30 plus post. Cost me more a while back, but decided to fit a blinkstop instead. So it’s never been fitted, basically as
new.
I’ll try and find details of it for you but it’s an American item for a motorcycle.
I used to be indecisive, but now I'm not so sure
kingster996
posted on 5/7/18 at 09:53 PM |
It’s one of these http://www.squaredeals-ltd.co.uk/kisantech-self-cancelling-flasher-relay-signal-minder-sm-3-mitsuba-plug-fitting-1290-p.asp and I
have a connector to fit the plug shown.
£80 new, so mine is a bargain
