New Topic New Reply
Author: Subject: Bending chassis question
Julian B
posted on 24/3/07 at 07:52 PM Reply With Quote
Hi
I was wondering how those of you who have built your own chassis, managed to combat chassis bending when welding the peices together?
Simon
posted on 24/3/07 at 07:59 PM Reply With Quote
When you start, make sure all the bottom pieces of chassis are champed to the board.
Pieces of wood screwed to board either side of rails, and pieces on top too.
Tack on verticals, then the next layer followed by triangulation pieces. When all tacked (whilst still clamped), you can start fully welding.
The clamping to base board and triangulation should prevent any warping.
Make you you do mirror welding - ie one weld on left, same weld on right and so on.
Simon
ecosse
posted on 24/3/07 at 08:21 PM Reply With Quote
Simon
Yeh, completely as above was how I did it (stock up on G-clamps ) , and my chassis is within 3mm everywhere I can measure (which i think is not bad going )
Alex
Chr!S
posted on 24/3/07 at 09:03 PM Reply With Quote
Thought id add that if you get the tubes aligned perfectly (ie no gaps at the joints) then with the correct clamps you can do it very accurately.
I tried the board method and the front moved. Junked it and did everything free-standing with clamps: max error of 1 and a bit mm Although the board method put the front (LC/LD? cant remember) went nearly 4mm to the left :s Managed to 'pull' some of it back in the end.
Basically make sure its held solid before welding and I mean SOLID. It *will* deform but it will be much less than millimetres if you clamp it right
caber
posted on 24/3/07 at 11:38 PM Reply With Quote
Assume there will be some deformation and weld your suspension pick up points so they provide square wheel locations. i.e. measure and mount to absolute dimensions with a jig don't rely on mounting dimensioned off the chassis itself. My chassis is about 4mm out but suspension pick ups are about as right as I can make them, say ±1mm.
Caber
robertst
posted on 25/3/07 at 04:02 AM Reply With Quote
i haven't clamped the chassis, or used a jig, just a huge workbench...
i even skipped the tack welding and welded everything fully as i went, welding is now complete, and the chassis is as straight as an arrow
Tom
JB
Senior Builder
Posts 436
Registered 20/5/04
Member Is Offline
Photo Archive Go!
Building: Built: V8 Kitten, 2 litre Lada, Space frame Minor,
posted on 25/3/07 at 07:51 AM Reply With Quote
It will move, if you are lucky it will move equally and end up something like afterwards.
The best thing you can do is mount and weld the critical points (suspension etc) last so they can be made to take into account and chassis twist / bending.
I layed all my tubes on a rough garage floor and levelled them with shims etc then tacked them. The suspension went on last.
New Topic New Reply
