DIY Si
posted on 18/7/07 at 06:42 PM |
Auto/bike electrician
Right, I'm now at the end of what I can do with my engine! I replaced a blown carb'd blackbird engine with an injected X11, but I just
can't get the injectors to fire. I had posted this in the bec section, but am in need of wider help now. The engine sparks, but I can't
see what stopping the injectors. All safety circuits cut out/earthed and the bank angle sensor and engine stop relay have been removed. I am now at a
loss to what else to do, so i require the services of someone professional.
Does anyone know of a good bike/auto electrician near Northampton who is able to do house calls, as I currently have no way of moving the car? Or
anyone willing to come and help for some beer tokens?
Editted fro shody splleing
[Edited on 18/7/07 by DIY Si]
Sun Tzu, The Art of War
blue2cv
posted on 18/7/07 at 06:52 PM |
Is your pos feed to the injectors ok, most systems switch earth to squirt (sorry if i'm trying to teach you to suck eggs)
DIY Si
posted on 18/7/07 at 07:01 PM |
yup, it runs a direct feed to the coils and injectors, as per the bike. Switched earth as you guess, but the switched side of the injector plug always
show 0V, but they don't do anything?! And my heads starting to hurt from thinking about it. The only other thing I can measure is the resistance
along the switch and it's 2.5 ohm between the batt negative and the plug. I'll go and try a new feed and see what happens, but I
can't see how it'll change, but you never know!
blue2cv
posted on 18/7/07 at 07:08 PM |
Have you tried earthing injectors manually, just to make sure they do work and also reduce the "why dont the bloody thing work " list
DIY Si
posted on 18/7/07 at 07:44 PM |
First thing I tried today, as I reailsed I hadn't actually done it yet. Oh, and scratch the ohm reading, my meters packed up. It thinks a
straight short is still 150 ohm!
Aaarrrrrggggghhhhhhhh, why won't it work!!!!?????
And breathe.
graememk
posted on 18/7/07 at 08:12 PM |
contact k33ts from this site
rusty
posted on 19/7/07 at 09:11 AM |
I'm not a bike expert but I have a good knolage of auto electrics, depending on your location I could have a look for a cup of tea.
DIY Si
posted on 19/7/07 at 04:37 PM |
I think I may live a bit too far away from you though! I live near Northampton.
r1_pete
posted on 19/7/07 at 07:33 PM |
Try Ferret, hes mobile:
http://www.mcrd.co.uk/home/a0_F/a0_FE/i208_Ferrets_Custom_Elecktrickery_-_Mobile_Service
Uphill Racer
posted on 19/7/07 at 07:48 PM |
Is it possible that one of the curcuits is in safety mode?
DIY Si
posted on 20/7/07 at 07:04 PM |
What do you mean by safety mode? They are all open or shut switches, so all should be ok.
Uphill Racer
posted on 20/7/07 at 08:09 PM |
A link made that should be open or a link open that should be made. It's a simple mistake that I made when wiring up my ZZR 11.
DIY Si
posted on 21/7/07 at 02:37 PM |
Ah, I get what you mean now. It seems to be that the way of not starting the engine is to stop the injectors, whilst still allowing the sparks. As far
as I can tell, all the correct things have been done, hence my growing confusion.
posted on 21/7/07 at 02:48 PM |
Sticking injectors?? 2 of mine were sticking until cleaned
DIY Si
posted on 21/7/07 at 03:44 PM |
Well, they all fire if flicked with with power direct from the battery, and the normal feed comes from the battery post on the starter solenoid, so
that is fine.
