eznfrank
posted on 4/2/08 at 06:24 PM |
Probably a daft diff question??
When a diff is referred to as 7 inch or 7.5 inch, what exactly does the measurement refer to??
A guy is supplying me with a full xr4i back end with discs but I think this is a 7.5 inch and I want to make sure I aint gonna have to modify a
standard MK chassis as I have ordered it powdercoated.
Dumb question?
Peter M
posted on 4/2/08 at 06:25 PM |
Measurement across diff mountings.
my previous cars
my westfield build
eznfrank
posted on 4/2/08 at 06:27 PM |
Ah, so I need to drop Mk a line and tell them it's that diff so the mountings are spaced correctly?
PAUL FISHER
posted on 4/2/08 at 06:28 PM |
Its the measurement across the top of the diff,if MK has not made your chassis yet or powder coated it,its not a problem,just ask them to to weld your
diff carrier to except the 7.5" diff.
I wish I could type faster
big_wasa
posted on 4/2/08 at 06:31 PM |
And there was me thinking it was the dia of the crown wheel ?
blakep82
posted on 4/2/08 at 07:02 PM |
thats what i thought...
________________________
jacko
posted on 4/2/08 at 07:13 PM |
It's both
Chippy
posted on 4/2/08 at 11:18 PM |
If its from an XR4i, or XR4x4, I am pretty sure that it will be a 7" diff, (and possably a LSD). I think that the 7.5 one was only fitted to the
Granada. May be wrong but don't think so. Cheers Ray
Mr G
posted on 6/3/08 at 03:08 PM |
V6 XR4i diff is 7" non LSD.
Rear brake setup is drums as standard not discs, so if it's got discs fitted they must have fitted a xr4x4 rear end which would mean shafts
would be lobro with an LSD. Failing that they've stripped the drums away,added caliper backets and done a disc conversion that way.
Or is this rear end off a 2.0 1990's XR4i ??
[Edited on 6/3/08 by Mr G]
