tyson1982
posted on 4/5/08 at 06:31 PM |
R1 main switch (cant get it to start)
Hi all
I have just transplanted an R1 engine into my kitcar. I purchased the loom and engine but totally forgot about the main switch (spent all day cursing
as I couldnt fire the bl""dy thing up). The engine is 98-99 model. Can any one tell me how to bypass this switch as I REALLY want to start
my car tomorrow.
adithorp
posted on 4/5/08 at 07:28 PM |
Mine's an 06 injection engine so some of this might not apply to yours
You need to by-pass the side-stand and clutch switches (connect the wires together). Then make sure your tilt switch is the right way up (UP the right
way up on the side of the box, not on the top). Connect/switch the secondary ignition wires together. Connect/switch the stop switch wires together.
Switch the primary ignition wires together. Earth the start wire. Should go providing the 99' engine doesn't have the immobiliser
system!
This might help; would never have sorted mine without it.
http://www.robcollingridge.com/kitcar/design/engine/electrics.html
adrian
Davey D
posted on 4/5/08 at 08:06 PM |
you only have to bypass the side stand, and clutch switch if you are starting it in gear.
If it is neutral, then it should still start
ch1ll1
posted on 4/5/08 at 09:14 PM |
start/stop= red + red and white wires.
starter = black + blue wires
from memory,
not sure if you mean that or the main key switch block
paul
tyson1982
posted on 4/5/08 at 10:15 PM |
Firstly thank you all for such a quick reply. Going to be honest, I cant make sense of the wiring diagrams (good with old mechanics but thats where it
ends
I have sorted the stand and clutch switch's and the engine is in neutral. I have the switch gear plugged in (does it need to be earthed?). It
does have an immobilizer but I have the key fob. As for the tilt sensor, I havent come across this before what do i need to do? (sorry wasnt 100% sure
and ive already spent a day trying to sort mess the resembles my wiring loom).
If someone could tell me what wires (colours) I need to sort (for the main ignition) I would be so greatful. If you live close enough and have the
answers I will happily reward you with beers as I am SO EXCITED about finally starting her up.
p.s. I have looked at wiring diagrams but I cant find one that relates to a 98-99 model (and that tells you how to hotwire it lol).
I will post some pics soon, the entire project has come in at under £1300 so far which isnt bad for a budget trackday weapon (if i can ever actually
start it![](/images//smilies/smile.gif)
Davey D
posted on 5/5/08 at 07:27 AM |
does the engine crank , and sound like its trying to fire when you press the start button, or does it do nothing?
Where abouts do you live?
tyson1982
posted on 5/5/08 at 09:45 AM |
Its totally dead, if I could get the main ignition sorted then I think I woul be fine. I'm based in Borehamwood, hertfodshire but would feel
very guilty getting someone to do my work.
Thanks in advance for te help
ko_racer
posted on 5/5/08 at 10:18 AM |
From the wiring diagram I have you need to connect the following (assuminig you've sorted the clutch & side stand switch)
Main IGN:
Big White 2 pin connector:
Join Red to Brown/Blue
4 Pin IGN Connector
Join Blue/Red to Blue and
Blue/Yellow to Black
For Right hand switch gear (Eng Stop & Start)
6 Pin brown Connector:
Start - Mom join Black to Black
Eng Stop Bypass- Join Red/White to Red/Black
The 4xv R1 doesn't have a tilt sensor, that's for the injection engines.
You must have the exup motor plugged in or it'll not rev properly once running on the road.
I'm only in Welwyn so if you are still stuck drop me an email at keith@koracing.co.uk and I can always pop down to give you a hand.
Regards
Keith
tyson1982
posted on 5/5/08 at 11:52 AM |
THANK YOU SO MUCH, I am going to get started right now (my girlfriends going to love me haven't left the workshop all weekend lol).
