Rallye_Mark
posted on 5/8/08 at 10:13 PM |
Manual Gearbox for 7.2litre Mopar V8?
My mate and I are doing a conversion in an old Dodge Dart and it came with a crappy Auto Box, I was just wondering what car would be a good source for
a gearbox for this monster of an engine. It should be about 500hp and 500ftlbs of torque before we charge it
Cheers Mark
skodaman
posted on 5/8/08 at 10:43 PM |
If you believe the bec boys on here a hayabusa box will take that amount of power, and as it comes coplete with engine as one unit u could use the
engine as a starter motor. It should be powerful enough though it might not have enough torque.
Skodaman
mr henderson
posted on 6/8/08 at 05:53 AM |
The american solution would be to uprate the auto box, and there are various kits available from US suppliers to do that.
John
imp paul
posted on 6/8/08 at 06:33 AM |
or try this chap http://www.john-sleath.com/portfolio4.htm#imp
chrisj
posted on 6/8/08 at 06:39 AM |
Tremec TKO 500 ? I think they do a six speed now as well
BearingKits
posted on 6/8/08 at 07:45 AM |
We have a used Viper / Aston Martin type Tremec T56 in stock.
The T5 will need to be highly uprated if you want it to last.
www.Bearingkits.co.uk
Gearbox, Differential and Axle rebuild parts.
speedyxjs
posted on 6/8/08 at 11:31 AM |
thedrivenman.com do a 5 and 6 speed box designed for the jag V12 but can (apparently) take up to 7 - 800 horses
Benonymous
posted on 6/8/08 at 12:56 PM |
Dinosaur box
You might be looking at one of the older style yank gearboxes. Over here in Oz with the local fetish for yank V8's I recall the T-10 gearbox
was very poular. There was another called a "Rock Crusher". All are deplorable 4 speed 'boxes more suitable for a small truck
rather than a car and I recall the "Super T-10" fitted to a friends 300Hp GM V8 almost needed two hands to shift from 1st to 2nd. But I
suppose it all goes with the territory if you must have an enormous lump of cast iron bolted into the front of your car.
P.S I'm no fan of the yank V8 in any form.
mr henderson
posted on 6/8/08 at 01:06 PM |
quote: Originally posted by Benonymous
Over here in Oz .
Be a good idea to put your location in your profile so that when people read your posts they can imagine the aussie accent.
John
posted on 6/8/08 at 03:50 PM |
The orignal Chrysler trans would be a Torqueflite ---- that is far from crappy a very good transmission best automatic of its day.
bj928
posted on 24/10/08 at 04:07 PM |
that is the same engine as the jenson intersepter of the 70's, so a manual 2 or 4 wheel drive is available i guess from a breakers/salvage yard
in england, just needs a look.
akumabito
posted on 24/10/08 at 04:48 PM |
You need to order the Summit Racing catalog! LOADS of yank goodies!
http://www.summitracing.com/
As for transmissions, check Richmond:
http://www.richmondgear.com/01transmissions.html
mr henderson
posted on 24/10/08 at 05:06 PM |
I should think the majority of Jensens were automatics, and with the chance of finding any big Jensen in a scrapyard being very tiny indeed,
the chances of finding a manual gearboxl let alone one from an FF, from that source has got to be extremely very tiny and small
jacko
posted on 25/10/08 at 02:23 PM |
R34 Skyline that will take the power
I don't know about fitment to that engine though
Jacko
