tegwin
posted on 17/10/08 at 02:27 PM |
What causes hot engine?
Would a leaky exhaust manifold cause the engine to run overly warm?
[Edited on 17/10/08 by tegwin]
www.verticalhorizonsmedia.tv
Mr Whippy
posted on 17/10/08 at 02:31 PM |
hmm not normally, not a good idea though as the gas can burn through things, like say a fuel line . Can't see it having any effect on timing
etc
actually if you have a Lambda sensor the engine can get the mixture wrong as it draws in fresh air and dilutes the exhaust gas, or so I read somewhere
[Edited on 17/10/08 by Mr Whippy]
82 Locost
posted on 17/10/08 at 02:33 PM |
Unlikely
tomgregory2000
posted on 17/10/08 at 03:01 PM |
dought it, maybe put come water in the cooling system
r1_pete
posted on 17/10/08 at 03:38 PM |
Things that could cause it:
sticky thermostat.
Slipping pump drive belt.
Blocked rad, or rad too small.
Ignition retarded.
Mixture weak.
Blown head gasket.
Blocked or kinked rad hoses.
Binding brakes.
andylancaster3000
posted on 17/10/08 at 04:05 PM |
Leaky manifolds can cause fires though. This happened:
...due to tiny leak in a collector weld near the above engine mount.
posted on 17/10/08 at 04:27 PM |
Ignition Timing too Retarded will cause boiling as soon as the crankshaft speed is above about 1700 t0 2000 rpm
zetec7
posted on 17/10/08 at 06:53 PM |
X2 for the ignition timing - I had an issue with the timing on my Fiero GT...and all 6 pipes were glowing orange hot, even at idle! Check your
timing...
http://www.freewebs.com/zetec7/
tegwin
posted on 17/10/08 at 07:10 PM |
The timing may be the issue...but if I advance it any more it pinks like a monster!
