Sierra rear discs , calipers and brackets. After £150 plus postage.
Also have 3.14 sierra dif and 3.92 diff. Both have push in shafts and are non lsd types.
After £300 for the 3.14 and £100 for the 3.92 plus postage.
Megabusa standard exhaust manifold and silencer, £190 plus postage.
Any questions then get in touch.
Free Bump..
How the h3ll did you managed to get the calipers so shiney??
Thanks in advance and good luck with sale...
AA
Is 3.14 still available?
Hi, yes it's still available.
Will you sell the caliper brackets alone?
Are they 2wd cosy calipers? And do they have the sliders?
Hi femster87, want to sell as complete kit .
They are not cosy calipers but do have sliders.
Does the silencer have an integrated catalyst, and if it does would you consider selling it separately to the manifold? If the answer to both of these is a yes then let me know what price you'd be willing to let it go for.
Hi, it doesn't have a catalyst.
Fester
I have the brackets in stock and your only down the road.
http://www.mksportscars.com/parts-c3/brakes-c4/disc-brake-adaptors-p30
Thanks Danny
Just wanted to say 'thank you' to Peter.
Parts arrived well packed and as expected.
Now to get my MK back together for the spring.
hi, is the manifold still for sale? if so could you take some measurements of the port spacing and the diameter of the bit that goes into the exhaust port. I need a manifold to fit a ZX12r motor, suspect a busa one isn't far off !
Hi, first chance to check sizes, apologies.
The Manifold end is 45mm ports with 90mm centers.
The silencer is 2 1/2 in .
Cheers Peter
