I'm going to make an instrument binacle by bending a wire frame to the perimeter shape I want and stretching an old tee shirt over it the way
home made sub enclosures are made. Has anyone done this? what are the usual pit falls?
For those who don't know, you paint the stretched tee shirt with resin to make it hold its shape then apply fibreglass to the surface once it has
hardened. Hey presto! compound curves!
know nothing about it but really interested to see the results!!
Originally posted by smart51
I'm going to make an instrument binacle by bending a wire frame to the perimeter shape I want and stretching an old tee shirt over it the way home made sub enclosures are made. Has anyone done this? what are the usual pit falls?
For those who don't know, you paint the stretched tee shirt with resin to make it hold its shape then apply fibreglass to the surface once it has hardened. Hey presto! compound curves!
Fleece jacket/jumper material works well for this job.
I have used artist canvas in the past, soaked in resin as it dries it shrinks tight.
i found the material used for longjohns is best as it stretches in all directions and doesn't dip when you apply the resin.
