Roll cage brackets for rain light
joemotion - 18/4/12 at 08:31 PM
As above does anyone know where to get a nice bracket for this
http://www.merlinmotorsport.co.uk/p1454/HIGH-VISIBILITY-RAIN-LIGHT-FIA/MSA-APPROVED/product_info.html
Want to run a couple of them as high level brake lights on my full cage
seen one on this nice MNR
http://www.pistonheads.com/sales/3808881.htm.
The only brackets i have seen are the from longacre and are not cheap Universal Rollbar Cage Mounting Bracket 1-3/4' Roll Bar | eBay
Motorsport Tools - Universal Rollbar Cage Mounting Bracket 1-3/4' Roll Bar
[Edited on 18/4/12 by joemotion]
lsdweb - 18/4/12 at 09:34 PM
Save yourself £20 on the lights and buy them from Maplins -
link
You'll need to solder in a 10p resistor though :-)
Regards
Wyn
johnny chimpo - 31/8/12 at 07:19 PM
Did you ever get an answer for this?
joemotion - 1/9/12 at 09:58 AM
No mate nothing else recommended. put this on back burner for now however will probably sort over winter. if you find anything let me know.
ed1801 - 1/9/12 at 10:37 AM
You can't use something like this then?
http://www.burtonpower.com/metal-p-clip-1-3-4-45mm-stainless-steel-lma412ss.html
bi22le - 1/9/12 at 11:50 AM
Also, assuming your going to put this at the top of the cage in the middle, how are you going to run the cable?
My old MAC1 had three of them lights high up on the full cage. They had welded a special little plate and surround to the cage prior to powder coarting and drilled holes to run the wires. It looked extremely neat and tidy.
