Bike carbs fuel pump location
Charlie_Zetec - 29/6/11 at 02:08 PM
Looking at places to install the fuel pump for my zetec on bike carbs.
Is there anything I should be thinking about before I find a home for it, such as vertical or horizontal fitting, below the fuel tank, etc.?
Advice appreciated, pictures even more so!
jossey - 29/6/11 at 02:13 PM
dont people put it at the fuel tank end?
bbwales - 29/6/11 at 02:39 PM
Hi,
I have mine mounted on the chassis by the fuel tank with no problems, I also have a filter before the pump, and am running a Zetec on bike carbs.
Regards
Bob
wylliezx9r - 29/6/11 at 02:54 PM
Mine is located on engine side of tranny tunnel and works a treat.
whitestu - 29/6/11 at 03:38 PM
Definitely put it at the back of the car close to the tank.
I had mine initially in the engine bay and it worked fine. However I kept getting minor air leaks which meant the pump kept running when it should have stopped.
I moved it to the back of the car just underneath the tank so it was gravity fed and since then I havenīt had any more problems.
Stu
jacko - 29/6/11 at 04:08 PM
Bike ticker pumps push the fuel so it wants to be at the rear next to the tank mine is horizontal
I hope this helps
Jacko
stevec - 29/6/11 at 04:28 PM
Another vote for rear, mine kept dying at the front.
daviep - 29/6/11 at 04:40 PM
Mines on the bulkhead in front of the scuttle, worked perfectly for 2000miles and still working.
Davie
[Edited on 29/6/11 by daviep]
bigfoot4616 - 29/6/11 at 06:00 PM
i know everyone recommends them at the rear but when i got my car it was at the front.
3 years later with a few thousand road miles and about 20 trackdays its never caused me any problems
kipper - 29/6/11 at 07:40 PM
I have mine at the front on the bulkhead, went all over northern france and belgium with no bother.
Regards Denis,
