Hayabusa turbo
peter bland - 24/4/16 at 11:22 AM
Have a problem with the clutch slipping when on boost.
I have heavy duty springs fitted and only running 5psi.
Before turbo it behaved fine. Just wondering if I need new plates although the current ones only have 3 tho miles on them.
Any advice would be appreciated.
Matt21 - 24/4/16 at 11:47 AM
You will most likely need a lock up clutch.
The extra power on boost over standard power is too much for the clutch.
Something like this;
http://psycleworkz.com/#/on-line-shop/4558416390/2--stage-lock-up-clutch/763779
You'll also need to modify/spacer the clutch cover so it will fit.
Utahfab - 10/2/17 at 06:51 AM
Just joined and saw your post. Another option is NLR Boost Compensating Lock Up Clutch.
https://store.schnitzracing.com/nlr-boost-compensating-lock-up-clutch-suzuki-gsx1300r-hayabusa-99-15/
Expensive as heck though I'd think it's the perfect application.
Billy
peter bland - 10/2/17 at 12:28 PM
I fixed it with a set of new original clutch plates. Now running 7psi with no problems.
Cheers Peter
Nickp - 10/2/17 at 12:51 PM
Cheers Peter
I think it could be on borrowed time though
bi22le - 10/2/17 at 01:03 PM
Cheers Peter
No if he drives like Miss Daisey.
Nickp - 10/2/17 at 01:09 PM
Cheers Peter
Kinda pointless fitting the turbo then
Last clutch only managed 3K when it was NA so how long will it last with boost?
peter bland - 10/2/17 at 01:23 PM
Drive it like its stolen.Did Austrian alps last year , and plenty of weekend blats , not a problem. Thanks for all the advice.
