TheHighlander123
posted on 23/10/16 at 05:56 PM |
quote: Originally posted by CosKev3
Cracking on nicely
How is the current loom made up,engine loom separate to car loom or is it all in one?
It's all one loom, removing it all
Made alot more progress last night and today. It's nice just working away myself in the garage.
Removed the gearbox
Removed the prop
Removed the dash and gauges
Removed the carbon wind deflector
Removed the seats
Removed the Steering column
Need to remove the fuel pump then start taking the arms off, body off etc
So easy to work on, I mind my Escort Cossy was a nightmare to work on due to space, same with the Evo aswell. Not bashed my knuckles yet.
Going to pick my cradle up and drop my ZX9 loom off at SKC this weekend, will also order up my prop and gear change kit.
Westfield SEIW 1700 Forged crossflow, twin 40s etc etc etc - Now about to do a ZX9R
TheHighlander123
posted on 2/11/16 at 08:47 PM |
A update for this
Wiring loom fully removed and labelled
Dash removed and all clocks
Underside degreased
Removed wings
Car is a bare shell, just need to remove the cage and bodywork
Manifold purchased - Going to fife to pick this up on wednesday
Baffle plate for ZX9 sump
Collected engine cradle from SKC
Loom is at SKC (took it down on Friday) so they will be doing this but will give them the car once i mount the engine.
TheHighlander123
posted on 10/11/16 at 08:19 AM |
Drove to Fife yesterday to collect a manifold and baffle plate.
Going to mount the engine when i come back from work on Sunday and after the rugby.
SKC have finished my engine loom which is good.
Gre3D
posted on 16/11/16 at 11:51 AM |
nice car,
good luck with your winter project!
i'm following your work :-)
TheHighlander123
posted on 16/11/16 at 09:55 PM |
Thanks mate.
Well I have been working away at this but not updated it.
Engine mounts have been tacked in and the cradle drilled to suit.
Need a couple of longer bolts for the bottom.
Manifold has been mounted just need to jiggle it about.
Getting there
TheHighlander123
posted on 22/11/16 at 09:10 PM |
This weekend I painted the engine cradle black.
Bought a reverse kit off Jamesc on here (bought it tonight)
Will be fitting the engine tomorrow and measuring up for getting the prop made.
Gre3D
posted on 22/11/16 at 09:52 PM |
Where do you get a propshaft made? Is it expensive?
TheHighlander123
posted on 23/11/16 at 08:10 AM |
Not had it done yet.
Need to measure the length.
Been told about £300
adampage
posted on 23/11/16 at 08:29 AM |
Getting there...
Hey, sounds like you're getting things done.
You'll just be ready for when the hard winter sets in! Fingers crossed for some of those bright & dry days when you can get it out on the
road again.....
Ad![](/images//smilies/bigsmile.gif)
TheHighlander123
posted on 29/11/16 at 09:53 PM |
Thanks Adam.
Getting there now.
Today I ordered
Billet gear shifter and cable
2 piece TRT propshaft
Also
Reverse kit arrives yesterday
On Sunday I finished all the welding
Cleaned up all the welds
Painted the engine bay
Car is going to SKC to have
Reverse kit fitted
Prop fitted
Wiring loom fitted with clocks
Coolant hoses fitted
Then I will get it back and tidy it all up and then we are rolling
TheHighlander123
posted on 11/12/16 at 08:31 PM |
This afternoon I did a little bit more.
Engine/Cradle has now been bolted into place for the final time
Manifold fitted
Link pipe is being welded tomorow for my exhaust
Ordered new steering rack gaitors
Ball joints
Getting very close now
CosKev3
posted on 11/12/16 at 09:25 PM |
Looking good
What's sump to road clearance like?
TheHighlander123
posted on 12/12/16 at 03:10 PM |
Looking good
Not measured it but I have more clearance with this than the other engine so won't have any issues.
Dropped my bike can and collector off to a customer of mine to be welded today. Should have it mid week.
Getting closer now.
adampage
posted on 12/12/16 at 04:10 PM |
Going well!
Well done!
We have our engine/box/prop in & mounted, the gearshift extender 'just' clashes with a chassis tube but we'll work a way around
that, and we're just doing plumbing, cables etc!
So we're getting on ok too.....
Ad
TheHighlander123
posted on 14/12/16 at 08:41 AM |
quote: Originally posted by adampage
Well done!
Ad
Excellent news Adam.
Looks like we are both making good progress.
TheHighlander123
posted on 14/1/17 at 11:15 PM |
Drove 168miles to Scottish Kit Car Centre today to drop off my Westfield.
They are going to
Fit prop
Fit reverse kit
Order me a carbon dash and fit my savage switches
Fit wiring loom
Fit gear change kit
Fit throttle/clutch cable
Get the car running.
Can't wait to get it back already.
Had a poo week, manage to crash my company car, put it on it's side. Made it up to Thurso in the snow and back then crashed 1 mile from my
house, luckily uninjured but the car was now, fair bit of damage. Get my new company car which I ordered last year in March so not sure what we are
going to do.
Gre3D
posted on 10/2/17 at 11:05 PM |
too bad you crashed your car man!
but look at it on the bright side, your westfield is nearly runing! keep up the work ![](/images//smilies/smile.gif)
