cfc999
posted on 28/1/18 at 03:53 PM |
1995 zx9r powered Sylva Striker project start up.
Here's a short clip of my zx9r powered Striker starting up for the third time. It's going to be use for hillclimbs and sprints so
it's a lightweight basic build in a bid to improve performance. I've fitted a secondhand pro-shift gear change system using buttons on the
steering wheel to shift up and down.
Its been built on a shoe string budget so it might be a little old school but it's all I can afford at the moment.
The engine is a big bore TTS built version and originally came out of a Tiger. Mk did the chassis modifications and we managed to keep the original
Tony Law exhaust manifold.
Still quite a bit to do but its getting there slowly.
https://youtu.be/nxhWaVp-37A
Mark RSP
posted on 19/1/20 at 07:09 PM |
Nice bit of kit as I have ZX9 powered styker too running CR 42mm flatsides and hoping to fit a dry sump kit to it
cfc999
posted on 20/1/20 at 11:19 AM |
Sounds good
Could do with picking your brains
Can I send you my number so I can contact you via WhatsApp if that’s ok
Chris
