sebastiaan
| posted on 4/5/20 at 01:07 PM |
quote: Originally posted by flak monkey
Slowly making some progress.
Made a couple of odd little plenum things - one for MAP signal to the ECU and the other as the IAC distribution to each throttle body, but I might do
something else for the IAC, I haven't decided yet.
Intake manifold arrived yesterday afternoon, so I managed to get the throttle bodies re-spaced and offered up for test fitting.
Great work. Careful though; mounted like that you may or may not be able to still balance the ITB's. I've them mounted the other way
'round and in my application it would be impossible to get to the balancing screws.
flak monkey
| posted on 4/5/20 at 01:18 PM |
Accessible from underneath, same as usual
Sera
http://www.motosera.com
Abe
| posted on 4/5/20 at 07:47 PM |
Good stuff!!
flak monkey
| posted on 7/5/20 at 01:35 PM |
Did some welding.... hopefully it will fit and clear everything... if not, then I'll be modifying it!
Sera
peter030371
| posted on 11/5/20 at 12:35 PM |
Hi Sera, sorry another question if you don't mind
I stripped my head at the weekend and I can't decide if my valve stems/and or guides are worn or not (never stripped any head like this before).
I can't find any data online but do you know what is acceptable if I measure the valve stems (I think they are 5.48mm new)?
| posted on 11/5/20 at 01:29 PM |
Valve guide/stem wear is normally checked by putting the valve in the guide and holding it off the seat check the sideways movement
peter030371
| posted on 11/5/20 at 01:38 PM |
Which makes perfect sense as the valve stem and guide are working together but what is 'acceptable' sideways movement? From what I have
read its seems down to experience but I have none
