Author: Subject: just got a milling machine need advice
thunderace
posted on 4/9/09 at 11:10 AM Reply With Quote
just got myself a small milling machine to remove some fins in a rocker cover ,i have used a router for years,
1. do i need to go anti clockwise when cutting?
2. what bit do i need to remove alloy the fins ,its a clarke cmd10 micro milling / drilling machine.(ebay link would be nice)
3 what speed should i do it at ,its max is 2000rpm.
(i also need some sort of clamps to hold the rocker cover)
this is what i got
this is what i want to do with it.
Danozeman
posted on 4/9/09 at 11:18 AM Reply With Quote
A mill for that? Id use a sander.
Dan
posted on 4/9/09 at 11:24 AM Reply With Quote
A Dremel might be easier.
r1_pete
posted on 4/9/09 at 11:25 AM Reply With Quote
Me too then have the polishing wheel keep chucking it at the floor
De Logo'd several zetecs with a high speed air sander.
[Edited on 4/9/09 by r1_pete]
GrumpyOne
posted on 4/9/09 at 11:28 AM Reply With Quote
Yes it would be easier, but if he had told his wife that, he wouldn't have been allowed to buy the milling machine. Come on guys
My wife is very understanding, she understands that if I am in the garage I am not in the house annoying her.
rallyingden
posted on 4/9/09 at 11:36 AM Reply With Quote
I quite like it blue WITH fins
RD
r1_pete
posted on 4/9/09 at 11:37 AM Reply With Quote
Yeah, my Mrs. wouldn't have fallen for that, response would have been along the lines of why polish something up which lives under cover.....
MikeR
posted on 4/9/09 at 11:59 AM Reply With Quote
why not just use the shiney one in your post and sell the blue one to cover the cost of the miller....
(sorry, I appreciate this was a completely unhelpful post, its friday)
posted on 4/9/09 at 12:59 PM Reply With Quote
I'm with your missus on that one.
omega0684
posted on 4/9/09 at 05:36 PM Reply With Quote
personally i think having chromed or polished bits under the bonnet is pointless, you spend forever polishing them, go out for a blat and then they are covered in crap all over again! chromed stuff flakes and starts rusting with time as well,
personally i like the blue one better as well!
just my 2 pense worth.
big_wasa
posted on 4/9/09 at 06:31 PM Reply With Quote
Dont take this the wrong way but that machine is bugger all use for car sized parts.
The main drive is a little white nylon cog driven by a steel wood ruf key.
As soon as you put any load on the chuck it will strip.
Give me a u2 when you have as I have three spares lol I returned mine for a refund after two days of buying it.
Imho its only any good for modeling.
owelly
posted on 4/9/09 at 07:37 PM Reply With Quote
Grab hold of the chuck and try to move it sideways. If there's any movement, don't use milling bits. They'll dig in and wobble about. I'm unsure how you're going to use such a small machine to mill a cover.
http://www.ppcmag.co.uk
Litemoth
posted on 4/9/09 at 08:34 PM Reply With Quote
Get yourself an 8mm or 10mm slottig drill or end mill and a peice of plate (at least 6mm thick, big enough to clamp the rocker box down onto and clamp the plate to the bed. It's only aluminium so isn't going to be hard to mill but all the finishing really isn't going to be worth the bother.
You'd be better off getting a rough sanding disc and backing pad (pr flap disc) for an angle grinder and just 'grind' the fins off. Wear a mask though!
Li nky to Disc
rf900rush
posted on 5/9/09 at 06:56 AM Reply With Quote
Hi
Slightly of you quest, but..
Get some stepper motors and Stepper Drive elextronics, the find some online (FREE) software , and hey presto you will hav a small CNC mill.
for example LINKY
Did that to mine and is great for little custom parts.
Do a Google search on DIY CNC.
Martin
RobMarshall
posted on 6/9/09 at 09:10 AM Reply With Quote
I have to agree with some of the above comments, sanding the fins off would be simpler. I have not looked closely at this Clarke milling machine, but the strength of the gears in their lathes is hopeless. The one I tried to use stalled if I tried to take more than a 0.3mm cut.
Theshed
posted on 6/9/09 at 07:48 PM Reply With Quote
Use a 10mm end mill. Go slow on feed take light cuts at about 1000 rpm and all will be fine. Lubricate with parafin. You might have been better off with a bigger toy but milling machines are great toys.
