Author: Subject: Fuel Problem
Puzzled
posted on 20/1/10 at 06:04 PM Reply With Quote
Fuel Problem
Right--- everything hunky dory, or so I thought.I have finished the build, car starts and runs like a dream. Timing spot on and ticks over like a Ladies Watch!!.Went for a bit of a spin , to iron out rattles etc , everything going grand ,then I come to a full stop, engine just dies. With my limited knowledge I diagnose "Fuel Problem". Take off feed to Carb (from fuel vapour separator) no petrol coming when engine cranked. Take off pipe from pump to seperator and get drenched in fuel!!!.Look in the Book and while this unit (Separator),is mentioned , and can be "Faulty" it does"nt say what it does or how it can be fixed if it is faulty. Anyone able to explain or help please??
jacko
posted on 20/1/10 at 06:17 PM Reply With Quote
Engine ?
Puzzled
posted on 20/1/10 at 06:25 PM Reply With Quote
fuel problem
Sorry ------ 2litre pinto Carb
carpmart
posted on 20/1/10 at 06:36 PM Reply With Quote
To the O/P, this is the wrong section for this post and need to go in engine section! You will get many more replies there!
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
flak monkey
posted on 20/1/10 at 06:38 PM Reply With Quote
Dump the seperator, you dont need it!
Sera
http://www.motosera.com
jacko
posted on 20/1/10 at 06:55 PM Reply With Quote
Dump the separator, you dont need it!
I second that dump it
MakeEverything
posted on 20/1/10 at 07:01 PM Reply With Quote
Makes sense to dump it.
Kindest Regards,
Richard.
Puzzled
posted on 20/1/10 at 07:03 PM Reply With Quote
Thanks for the suggestion, but when you say dump it, what do I do with the return to the tank???
RichardK
posted on 20/1/10 at 10:50 PM Reply With Quote
I thought that just had a fuel in and fuel out, so just take it off and join them together using an inline fuel filter or something. Using carbs it not usually necessary to have a return to the tank and if fitted to the carb like a dgas then it can be blocked off without any problems.
Rich
[Edited on 20/1/10 by RichardK]
Gallery updated 11/01/2011
fatbaldbloke
posted on 20/1/10 at 11:04 PM Reply With Quote
Hmm, for a carb setup the fuel should go from the tank to a low pressure pump, then through a filter (although there may also be a strainer in the tank). The fuel then goes into a pressure regulator (you're not getting this confused with a separator, are you?). This needs to be set at around 2.5 psi. The fuel then goes from the pressure regulator into the carbs, and that's where it stops, there should be no return.
Puzzled
posted on 20/1/10 at 11:28 PM Reply With Quote
Fuel pump is original mechanical one. the "Thingy" has 3 outlets.1 Feed from pump.2 Feed from "Thingy" to carb and 3. Return to tank.I can clearly see it in the book and its called "Fuel vapour separator".Now the concensus seems to be "BinIt", if I do then will I just plug the end of the return pipe??
Thanks for the help Gents
RichardK
posted on 22/1/10 at 08:37 PM Reply With Quote
Ahh, now I understand, the "Retrun" to the tank just went to the top of the tank to return the vapour to the tank, have you got it essentially submerged in the fuel tank? Maybe thats your problem, either way yep block it off and join the other two together.
Rich
