Author: Subject: Petrol Filters
rsmith95uk
posted on 5/8/10 at 04:35 PM Reply With Quote
Petrol Filters
had some fuelling issues when I changed from Webers to ZR6 carbs which resulted in a change of pump (to a ZR6 unit) and removal of a filter king regulator. I joined the break in the fuel line where the regulator was with another filter.
When ticking over, the new filter never seems to have much fuel in it! Should this fill up - the pre-pump filter does and the old regulator did as well?
Also, there are now three filters in the line - one pre pump, one that is part of the pump unit itself, and one pre carbs. Is this overkill, and could it restrict flow?
Ray
snapper
posted on 5/8/10 at 05:07 PM Reply With Quote
The extra filter will not fill up unless it is vertical.
When horizontal there is nowhere for the air to go
I eat to survive
I drink to forget
rsmith95uk
posted on 5/8/10 at 06:55 PM Reply With Quote
Snapper, the filter is vertical with input at the bottom.
Engine seems to be running OK in the garage (not taking it out for a run unless I'm confident I wont be stranded somewhere) but the petrol only seems to be filling the bottom of the filter housing by about a quarter of an inch and I can't see how the fuel is getting to the carbs!
Ray
deltron63
posted on 5/8/10 at 07:27 PM Reply With Quote
i did the same with mine, it never fills up but it works fine
MakeEverything
posted on 5/8/10 at 09:41 PM Reply With Quote
Beware plastic inline filters under pressure.
I had one baloon and pop, spraying fuel everywhere, including over the exhaust.
Make sure its glass or pressure rated.
Kindest Regards,
Richard.
rsmith95uk
posted on 5/8/10 at 10:21 PM Reply With Quote
thanks for the responses - I'll go for a blat and see how it fares!
Ray
