Author: Subject: Faulty injectors
Snuggs
posted on 30/10/10 at 04:14 PM Reply With Quote
Faulty injectors
What are the usual symptoms of a sticking injector ?
http://www.topcashback.co.uk/ref/snuggstcb
Spider pig, spider pig, does whatever a spider pig does.
I doubt therefore I may be.
Luposlipophobia : Fear of being chased by wolves around a freshly waxed kitchen floor, while wearing only socks on your feet.
My mind not only wanders, sometimes it leaves completely!
http://www.venganza.org
http://www.jesusandmo.net/
http://www.snuggs.co.uk
escary
posted on 30/10/10 at 04:21 PM Reply With Quote
injector
petrol or diesel?
direct or indirect?
Mark Allanson
posted on 30/10/10 at 04:28 PM Reply With Quote
On Alfa Romeo's, the injector runs lean, overheats the piston crown which melts, this now acts like a pump and sucks all the oil out through the exhaust ruining the cat, the mains and big ends run dry and then seize.All in 4 seconds!
posted on 30/10/10 at 04:29 PM Reply With Quote
As with a coil pack fault a misfire Pcode in the P03xx range pointing to a specific cylinder.
matt_gsxr
posted on 30/10/10 at 04:44 PM Reply With Quote
Poor idle quality.
Plug that reads different to the others.
I assume you don't mean sticking open. If so, a stink of fuel when the fuel pump is running even when the engine is turned off.
Matt
posted on 30/10/10 at 06:26 PM Reply With Quote
What symptoms have you got Clive?
stevebubs
posted on 30/10/10 at 11:11 PM Reply With Quote
usual symptom is either seriously lean or p!ssing fuel out the exhaust...
Dad had a short on his Rover 75 injector harness so it stuck open (bad maintenance by a non-dealer maintenance place led to chafing).
He basically could see his fuel needle dropping as he drove down the M40....
