J16
posted on 25/5/11 at 08:27 PM |
Diff help needed
Hi all
I'm trying to identify what ratio diff I have in my kit so I can configure my digidash. I've been through the diff codes thread at the top
of this forum but can't seem to find the matching code as well as a lengthy google search, tbh I just keep getting conflicting info.
Unfortunately the tag on the diff is corroded and no longer any use so all I have are the numbers stamped into the back of the diff which read as
follows:
83BG-4033-BA- D 04 BA
If anyone can make any sense of this please let me know. All I know is that it's a LSD.
Jk
austin man
posted on 25/5/11 at 08:41 PM |
doesnt it work in relation to the wheel circumfrence
HowardB
posted on 25/5/11 at 08:43 PM |
quote: Originally posted by J16
Hi all
follows:
Jk
can you do a mechanical test, and count the number of input turns to output?
Howard
madteg
posted on 25/5/11 at 08:44 PM |
What diff is if. You can always remove back plate and it will say it on the crown wheel.
snapper
posted on 25/5/11 at 09:13 PM |
3.6 or 3.9
Jack up rear (use axle stands) chalk mark on inside of tyre, chalk mark on prop flange, rotate wheel 1 turn, count prop rotations, should be 3 1/2 for
3.6, 4 for 3.9.
I eat to survive
I drink to forget
matt_gsxr
posted on 25/5/11 at 10:18 PM |
quote: Originally posted by snapper
3.6 or 3.9
3.6, 4 for 3.9.
If both wheels rotate once then the quoted text is completely true.
If you only rotate one wheel (and the other doesn't rotate) then you will need to rotate the single wheel twice to get these numbers.
This a very easy test to do.
Or if it is easier then take the back plate off and count the teeth on the big gear and the one that meshes with it and divide.
Matt
mcerd1
posted on 25/5/11 at 11:30 PM |
which they should if its a working LSD
or like madteg says if you take the back cover off its normally stamped / written on the crown wheel
like this:
[Edited on 25/5/2011 by mcerd1]
J16
posted on 1/6/11 at 09:40 AM |
Many thanks for all the replies. I've worked out that the diff has a ratio of 3.9 if anyone else finds this info of any use.
Jk
