hiflow
posted on 1/8/11 at 06:01 PM |
ZZR1400 , where can i get ecu unlocked
Have not got the key assembly or barrel. Where can i get the ECU unlocked , or can you buy a 'bypass gissmo' to make the engine run ?
minitici
posted on 1/8/11 at 06:12 PM |
Simplest way (and probably cheapest?) would be to get onto e-Bay.com and buy a USA ZX14 CDI ECU.
The North American version does not have any immobilizer nonsense!
Seems to be quite a few at $150-$250
Failing that contact Mal at Yorkshire engines and see if he has a US spec ECU.
[Edited on 1/8/11 by minitici]
eddie99
posted on 1/8/11 at 06:14 PM |
There is a place in norfolk that will either unlock your ecu or provide you an ecu unlocked in part exchange, i cant think of the name and a quick
google showed nothing. Give Andy Bates a call, he was the one that put me in touch with them.
hiflow
posted on 1/8/11 at 07:16 PM |
perfect, no need to panic afterall. Better go and give the man some money and make a purchase.
Complete 893cc Blade package for sale.
Look in For Sale for more info
ANdy
russbost
posted on 1/8/11 at 08:43 PM |
I've fitted 3 ZZR1400 engines now, only requirement to get them to run was to put a 100 ohm resistor on the pink wire to the ecu. Is there a
more sophisticated immobiliser around?
Only other thing I'm aware of is if you're not using the original speed sensor it won't rev over about 9,000, can't remember
exactly what you have to do to get around that, but pretty sure it's come up on here in the past.
