andylancaster3000
posted on 20/3/12 at 12:23 AM |
Trailer board material
I'm looking to make my own trailer board as I have all the bits and ones long enough are actually quite expensive.
Does anyone know where you can buy the white hollow plastic board from? Alternatively something else nice and cheap that would do the job?
gazza285
posted on 20/3/12 at 05:45 AM |
Courtesy of your local roadworks?
Macbeast
posted on 20/3/12 at 06:19 AM |
Homebase or B&Q - white plastic soffits ( I think that's what they're called - plastic planks behind and below your gutters)
Daddylonglegs
posted on 20/3/12 at 06:39 AM |
yep, soffits is what you need
Proby
posted on 20/3/12 at 08:16 AM |
That's what I was thinking before I opened and saw your pic! lol
owelly
+1 for road work barriers. I've made a few from them. I've also made a couple from 1.6mm sheet steel folded so the lamps are protected,
then powder coated.
http://www.ppcmag.co.uk
dhutch
posted on 20/3/12 at 08:28 AM |
Or just use some 6-8mm plywood? Presumably no where to direct mount them?
Daniel
andylancaster3000
posted on 20/3/12 at 01:18 PM |
Thanks for the ideas all. Can't seem to find quite the right stuff from soffit material - any links?
Can you buy those barriers rather then employing illegal means!
owelly
posted on 20/3/12 at 01:31 PM |
I bought a couple from HSS Hire. Paid cash and I'm sure the cash didn't go near the till....
Chippy
posted on 20/3/12 at 03:21 PM |
I have some offcuts of soffit material but a bit too far for you to pick up. Cheaper to buy local I would think. Cheers Ray
posted on 20/3/12 at 03:27 PM |
I used this from B&Q. Not the 5 pack they seel in singles as well.
http://www.diy.com/nav/build/timber/cladding/pvc-cladding/cladding/B-and-Q-PVCU-Cladding-Retro-White-L-2400-x-W-115-x-T-10mm-Pack-of-5-9976827
Confused but excited.
posted on 20/3/12 at 03:48 PM |
That's because you don't want a piece of soffit, you want a piece of facia. The soffit is the horizontal bit underneath.
HTH.
