itsawindupuk
posted on 18/4/12 at 11:41 AM |
duratec install with a creaking noise
hi guys, when i drive the car i get a strange creaking noise. its an mgb with duratec installed, its really hard to pin point the noise whilst
driving, but it only does it when in the lower gears and under load, like when pulling away. Any thoughts?
twybrow
posted on 18/4/12 at 12:11 PM |
If it is creaking, maybe it needs oil! ![](/images//smilies/wink.gif)
RichardK
posted on 18/4/12 at 02:13 PM |
Engine mounts would be my first guess
Rich
Gallery updated 11/01/2011
Chippy
posted on 18/4/12 at 03:56 PM |
Have you fitted poly bushes on the suspension, or even ordinary new bushes. If you have it could be that you have tightened them up prior to lowering
the car down on its wheels, just a thought. HTH Ray
itsawindupuk
posted on 18/4/12 at 06:35 PM |
i fitted poly bushes a year ago and it was fine with the previous engine. Perhaps the welding on my chassis mounts arent as good as i thought (arc
welding and im not good at it). Engine side mounts were made by a pro. Today i test drove it again and ive also got a noise which im certain is the
exhaust as its very close in places and it sounds metalic and hollow.
MkIndy7
posted on 18/4/12 at 07:16 PM |
What's controlling the engine timing?.. From the description of low revs and high load it could be pinking
