Doyleee
posted on 9/6/13 at 10:58 PM |
zx12r silver spark plugs
Hi i'm doing a few bits before rolling road tune up and wanted to change spark plugs just wondered if anyone had used these if so are they any
good?
Nology A0S Silver Spark Plug for a Kawasaki ZX 12R | eBay![](http://rover.ebay.com/roverimp/1/710-53481-19255-0/1?ff3=2&pub=5574934589&toolid=10001&campid=5336738914&customid=&item=123456&mpt=[CACHEBUSTER])
posted on 10/6/13 at 08:55 AM |
At £13.80 each I'd stick with something I know works.
Slimy38
posted on 10/6/13 at 10:08 AM |
Agreed, I've never seen any reason to move away from NGK.
posted on 10/6/13 at 01:54 PM |
Iridium is used by respected spark plug manufacturers (NGK and Denso) because it's extremely hard with a very high melting point, so you can use
a small electrode which gives reduced voltage requirements without it wearing out quickly.
The melting point of silver is way below that of iridium (and platinum), and it's a far softer metal. The better conductivity is of no
consequence whatsoever in an HT system, where the coil secondary and HT leads (and suppressors within the plugs, if any) will have several orders of
magnitude higher resistance then the centre electrode.
Nology also pedal some magic HT leads called "hotwires" for outrageous amounts of money and they don't provide the claimed benefits
either. Pure marketing guff.
In conclusion, stick to NGK.
posted on 10/6/13 at 05:49 PM |
We've used normal NGKs and Iridium & Platinum NGKs. Couldn't tell the difference between any of them performance wise. Not sure
whether they'd be longer lasting though...
Phil
Slimy38
posted on 10/6/13 at 07:29 PM |
Interestingly, did anyone notice that they poo-poo Iridium in the advert?
Hellfire, you are right, the perceived benefit of Iridium is longer lasting rather than a performance improvement. They are considered standard for my
tintop, with a 40,000 mile replacement interval. I would be looking to replace standard plugs every 10,000 miles.
Doyleee
posted on 11/6/13 at 06:53 AM |
Thanks guys take your point MikeRJ about silver having a lower melting point wanted to stick with the NGK CR9EKPA which is what i believe i have in at
the moment I'm not sure when they were last changed but I've had the car for about three years now and done less than 1000miles and
was'nt sure if these silver ones were new to the market or tried and tested by you guys
Thanks for your help i shall be ordering some NGK's straight away
