<<  1    2  >>
Author: Subject: Pre IVA Pics
leon51274
posted on 29/4/14 at 05:53 PM Reply With Quote
Pre IVA Pics
Evening Chaps
Sorry for flooding you out with my pics, but this is an opportunity for me to get you guys to give my car the once over prior to IVA, as this has now been paid for!
Any comments good bad or indifferent as always appreciated.
Leon
joneh
posted on 29/4/14 at 06:10 PM Reply With Quote
Could be the camera angle, but are those seats tall enough?
Lovely looking car! But I'd fail you on principle with that steering wheel! I assume that'll be off post IVA.
jacko
posted on 29/4/14 at 06:13 PM Reply With Quote
Very good
just one thing but i may be wrong side indicators are they ok there as i thought they had to be on the rear wing edges
As i say i may be wrong
Nice build my the way
Jacko
Are the front wing stay tops ok hard to see on photos
[Edited on 29/4/14 by jacko]
myke pocock
posted on 29/4/14 at 07:41 PM Reply With Quote
Think you wil find that the inner end of the track rod end (where it is a hex shape) will need to be covered with the plastic sleeving. When mine was IVA'd it was failed as the tester could still feel the hex shape through the sleeve and I had to wrap it with foam and then sleeve it.
gremlin1234
posted on 29/4/14 at 08:14 PM Reply With Quote
looks good
only thing I notice, I think the manufacturers plate has too much information
daveb666
posted on 29/4/14 at 08:23 PM Reply With Quote
Agree with the trackrod bolt. Will need to be covered.
How do the harnesses sit when you're in the seat? Looks like they may be resting on the seat??
leon51274
posted on 29/4/14 at 08:34 PM Reply With Quote
Is there a height requirement within the iva?
leon51274
posted on 29/4/14 at 08:40 PM Reply With Quote
Side repeaters was one thing I was expecting to crop up, they are mounted reasonably high up on the scuttle, I've had a look at roughly the correct distance and I think I may get away with them.
Wing stays, are you meaning the radius? If so then yes these have a decent radius.
Originally posted by jacko
Very good
Jacko
leon51274
posted on 29/4/14 at 08:42 PM Reply With Quote
I also had that feeling! I think I'll whip it off tomorrow and see if I can trim some off on the guillotine.
Originally posted by gremlin1234
looks good
Sloan85
posted on 29/4/14 at 08:43 PM Reply With Quote
Whats the radius of the bottom of the dash, or is it padded?
http://mkindygsxr.blogspot.co.uk
leon51274
posted on 29/4/14 at 08:45 PM Reply With Quote
I'll get these sorted, typically I did originally have these covered but decided to have a change as I had some heat shrink in the mix which was never going to be a goer!
leon51274
posted on 29/4/14 at 08:46 PM Reply With Quote
Its padded.
leon51274
posted on 29/4/14 at 08:49 PM Reply With Quote
Not got the car to hand at the mo but I think its close but does actually sit ok, I'll double check in the morning when I get back to work.
loggyboy
posted on 29/4/14 at 09:43 PM Reply With Quote
A very tidy build.
Mainly repeats of various above,
latest manual notes that the vin plate should contain AND be laid out exactly as shown on the manual, you can remove weight info etc, but not add anything, and must be in the right order.
Side repeaters, you have to remember its not only the 5degrees from the rear but the 5 degrees below horizontal. If you mark out 5 degrees from rear, which usually means you can just see them over the rear arches, but then drop your line of sight down below being level with the lights, I suspect they will disappear before you reach 5degrees.
Additionally to what others have said, is your fuel filler hose suitably marked for fuel or documened as such?
[Edited on 29-4-14 by loggyboy]
Mistral Motorsport
CosKev3
posted on 29/4/14 at 09:53 PM Reply With Quote
Radius on the gold coloured nut on the inside of camber adjusters on front wishbone?
davidimurray
posted on 30/4/14 at 08:01 AM Reply With Quote
Looks like a nice build. I think most of my points have been covered. Have you thought about the top of the front shocks? I put stretch boots over the shocks and all the inboard wishbone mounts. I also went overboard and covered every edge on the suspension just about. Are you putting covers under the dash? Helps keep prying eyes out! Have you got locking bolts under the roll hoop? Mine was bolted down to welded in nuts on the plate and he wanted to see locking nuts or spring washers on them. That and the headlight aim were the only things he picked me up on.
Some photos of my roadster Pre IVA are here - http://www.locostbuilders.co.uk/photos.php?action=gal&user=davidimurray&folder=Pre IVA
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
leon51274
posted on 30/4/14 at 09:00 AM Reply With Quote
This is a link to the filler hose that I bought from CBShttp://www.carbuildersolutions.com/uk/ultra-flexible-fuel-filler-hose-51mm-2 , they also supplied in a fashion a CofC, basically stating that the filler hose was suitable for fuel although the hose its self isn't marked.
u2u also sent
Originally posted by loggyboy
A very tidy build.
theprisioner
posted on 30/4/14 at 09:13 AM Reply With Quote
Don't know if this has been picked up already your rear lights indicators are not vertical?
Is there a tank breather and roll over valve or loop
[Edited on 30/4/14 by theprisioner]
http://sylvabuild.blogspot.com/
http://austin7special.blogspot.co.uk/
The Black Flash
posted on 30/4/14 at 10:09 AM Reply With Quote
It's only the fog light that has to be vertical, the rest are fine.
Looks a very neat build OP, well done.
Not sure about the space behind the dash, he'll put his hand in there if he can get it there and feel for sharp bits. Might be worth tacking a bit of carpet in there?
leon51274
posted on 30/4/14 at 10:13 AM Reply With Quote
Hi, yes there is a tank breather and roll over valve.
Not sure about the lights though!, I'll have a look at the iva manual but I thought it only applied to the reversing light?
leon51274
posted on 30/4/14 at 10:14 AM Reply With Quote
I'll sort this today as I couldn't for the life of me think of or find a suitable nut cover.
loggyboy
posted on 30/4/14 at 10:45 AM Reply With Quote
Doesnt even apply to the reverse, just the Fog.
Mistral Motorsport
leon51274
posted on 30/4/14 at 10:54 AM Reply With Quote
Sorry I meant to say fog!
CosKev3
posted on 30/4/14 at 11:06 AM Reply With Quote
Think I've seen people use a piece of bike inner tube
Smoking Frog
posted on 30/4/14 at 04:18 PM Reply With Quote
Secondary fixing for mushroom insert in upright? Fuel tank earth? Looks good!
<<  1    2  >>
