john.rigby247
posted on 13/11/16 at 11:34 PM |
Aeroscreen Mounting
Hello All
I'm after some help or advice with regards fitting a small screen to a STM Phoenix? I've tried searching here without success so apologies
if this has been covered before, but does anyone have advice on the best method to fix a screen to the body work, bearing in mind that my Phoenix has
the light weight body shell so not much to fix to!
Any thoughts would be very gratefully received as I have just bought some 3mm lexan, now I need to shape and fix!
John
[Edited on 13/11/16 by john.rigby247]
pewe
posted on 14/11/16 at 11:12 AM |
I formed some ali into the correct shape/angle (about 70 degrees IIRC) with a bottom flange which then bolted it to the bulkhead and then pan-head
screwed it to the screen with a thin strip of rubber in-between to give some cushioning.
If it doesn't curve towards the rear a couple of angled brackets at either end should give enough support.
Have a look at 1950/60's open top sports/race cars for ideas.
HTH.
Cheers, Pewe10
posted on 14/11/16 at 03:21 PM |
As above, unless there's a dedicated feature to bolt the Lexan to then I'd approach it with some Alloy brackets. You can buy right angle
Alloy strip so you could cut sections from it and bend it a little further to make what you need.
peter030371
posted on 15/11/16 at 08:20 AM |
Ask JeffW on here or the JPSC forum, I am sure he fitted his aero screen himself. Even if he didn't he can tell you how its fixed.
Huttojb
posted on 15/11/16 at 08:59 AM |
I used items like this;
eBay link
And fitted side mirrors though the screen to help strengthen
Jason
huttojb_GenTiger
There are only 10 types of people in the world. Those that understand binary and those that don’t.
If only DEAD people understand hexadecimal - 57,005
john.rigby247
posted on 15/11/16 at 09:08 PM |
Many thanks for all your replies, certainly some food for thought on how I can best complete this!
