Author: Subject: Westfield Megabusa ball joints track rods brakes etc...
Ian2812
posted on 25/4/17 at 07:02 PM Reply With Quote
Hi guys,
I am new to the kit car scene after always wanting one from a child.
I am currently overhauling a 2002 Westfield Megabusa BEC... I have a few jobs to carry out on the front end whist the engine and gearbox is out getting a new 4th gear / replacement box, which ever the outcome of the inspection is.
Whilst all this is on going I am going to replace track rod ends, upper and lower ball joints etc as all the rubbers are split.
I can buy all the gear direct from Westfield for a premium, however I am led to believe that all these types of components will be from a particular model of ford sierra or escort etc. so can buy from a local motor factors for a fraction of the price...
Does anyone know if this is the case and help to point me in the right direction..?
Many thanks.
Ian.
kingster996
posted on 25/4/17 at 07:09 PM Reply With Quote
Top ball joints are transit drag links. Bottom are Austin Maxi
Will try and find some part numbers or links for you.
I used to be indecisive, but now I'm not so sure
Ian2812
posted on 25/4/17 at 07:20 PM Reply With Quote
A few photo's of said parts...
kingster996
posted on 25/4/17 at 07:21 PM Reply With Quote
LOCOST & WESTFIELD TOP BALL JOINT / TRANSIT DRAG LINK END
UPPER OR LOWER BALL JOINT PAIR AUSTIN MAXI ALL MODELS Quinton Hazell
Pretty sure these are the track rod ends for the rack
TRACK TIE ROD END PAIR for FORD ESCORT MK 2 - 1974 to 1980 QH (Quinton Hazell)
Ian2812
posted on 29/4/17 at 03:33 AM Reply With Quote
Thanks for that Kingster996.
