Mike01
posted on 3/5/17 at 09:45 AM |
Haynes Chassis question?
Hi , so I am looking to build a Haynes roadsters and would like to build the chassis myself based on the book, I have done some rough working out for
the total number of meters required to build the chassis, I worked it out to be 10.5 m @19mm x 19mm and 28 m @ 25mm x 25mm all in 16swg....anybody
know if that sounds about right?
Dean m
posted on 3/5/17 at 10:08 AM |
According to the 'stickys' on the haynes forum in the FAQ bit, its says you need 7x 6m lengths of 25x25 and 3x 6m lengths of 20x20. There
will be some leftovers but you'll be glad you have them.
I bought a flat pack kit so didnt cut it myself.
What donor car will you be using?
http://forums.haynes.co.uk/showthread.php?t=8459
Hope the link works!
Mike01
posted on 3/5/17 at 10:14 AM |
Hi thanks for the link I can check my figures against there's now,I am undecided on a donor car at the moment, the mx5 seems cheap and plentiful
compared to the Sierra but I really have my heart set on a Ford power plant possible a zetec lump.
mcerd1
posted on 3/5/17 at 11:54 AM |
nothing much to stop you using mazda running gear and ford engine
you don't even need the ford gearbox - the RX8 boxes seem to be becoming a popular upgrade for ford engines now too:
http://www.turbosport.co.uk/showthread.php?t=980905
