Author: Subject: Made a lovely Welding Table (Video)
tilly819
posted on 6/7/18 at 10:42 PM Reply With Quote
Hi all,
I've been out in the workshop again, ignoring the missus, health and safety and all the jobs I was supposed to be doing. On the plus side I made myself a lovely new welding table.
http://youtu.be/9Usq71_QZVo
[Edited on 7/7/18 by tilly819]
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
J666AYP
posted on 6/7/18 at 11:07 PM Reply With Quote
Quality video mate, the bit with the hammers cracked me up.
Nice work.
Jay
ianhurley20
posted on 7/7/18 at 07:56 AM Reply With Quote
Brilliant video - well done! Subscribed
JonBowden
posted on 7/7/18 at 03:07 PM Reply With Quote
Ditto, excellent videos, I've subscribed too.
Will be very interested to see your crane video
I'll see how it compares to the one I made
Jon
mark chandler
posted on 7/7/18 at 10:30 PM Reply With Quote
Lovely table indeed
posted on 9/7/18 at 09:23 AM Reply With Quote
Great video and I have to say great welding table
From experience having a good table to weld on makes a big difference. Welding on the floor can get the job done, but a waist height metal table to work at makes it easier and nearly always results in a tidier weld.
jps
posted on 9/7/18 at 10:49 AM Reply With Quote
How do you manage to get such square cuts freehand with the angle grinder? Is it just practice? I am rubbish at it!!
jps
posted on 9/7/18 at 10:57 AM Reply With Quote
Originally posted by J666AYPThe bit with the hammers cracked me up.
We've all been there!
[Edited on 9/7/18 by jps]
tilly819
posted on 9/7/18 at 01:28 PM Reply With Quote
Thank you all
I scribe a line to follow then mike a light pass to just score the metal. Once i have a shallow groove that is straight I just work back and forwards keeping it in the groove. Using the thin slitting discs makes it a lot easier! Then it's just practice and a steady hand. One other thing that does help is not holding the grinder too tight; if you hand is all clenched up it will naturally shake, whereas if it is a more relaxed it will be nice and stable.
Tilly
jeffw
posted on 9/7/18 at 02:03 PM Reply With Quote
Nice table
posted on 12/7/18 at 09:54 PM Reply With Quote
Good job.
Can I ask why you did not tap the holes but instead welded on nuts, which I'm amazed you were able to do to a one inch steel slab.
I've found that welded on nuts can come away, obviously depends on how much weld is holding them but that can not happen with a threaded hole.
tilly819
posted on 13/7/18 at 05:31 PM Reply With Quote
Originally posted by 02GF74
Good job.
Thanks, and you sure can
It boiled down to time and effort. It took me a full day to drill all the holes due to the table top having some localised hard spots from where things had been welded down to the top by a previous owner. I didn't fancy the odds of how long it would take to tap all of the holes especially given the hard spots.
My original plan was to tap them M12 but in the end using M10 weld nuts seemed like an acceptable compromise. Only time will tell if it was the right decision. No doubt the table will get plenty of use in future videos so it will be interesting to keep an eye on.
Thanks, glad you enjoyed it.
Tilly
