Harryj1
posted on 27/2/19 at 01:20 AM |
1.6 pinto engine wiring
Hi im wiring a 1.6 pinto engine from scratch as im building a project car. It didnt come with any loom which is why ill have to wire it from engine to
lights etc.
I need help with the engine side of things for e.g. connecting the universal switch to the starter motor, coil and distributor.
Where will i need to put in relays and fuses .
Angel Acevedo
posted on 27/2/19 at 01:48 AM |
lights etc.
Welcome to the party...
I am halfway through wiring, I am mating a Fuel Injected Ford V8 to a Matiz column and switchgear with a generic pre-made harness.
There are several threads explaining specific requirements and wishes.
Try to get Electric schematics of car and switchgear to aid in "translation"
And regarding relays, easiest would be to use donor fusebox and relay box, or you can be as fancy as you want or as low tech as you are willing to put
up.
I haven´t tried to post pictures lately here, but I´m in Facebook as Angel Acevedo and you can see what I did with relays on my "Locost"
album.
Hope this helps.
snapper
posted on 27/2/19 at 06:48 AM |
If I was doing it again I would probably buy the CBS fuse and relay modial
I eat to survive
I drink to forget
Mr Whippy
posted on 27/2/19 at 07:14 AM |
The relays and fuses should be located in the passenger compartment to keep them dry and clean. A good place is above the footwell.
The pinto was often fitted with a ballast resister for the ignition so that during starting this resister was bypassed and full current fed to the
distributor and once the starter was disengaged current at a reduced voltage flowed to the distributor. If you leave this out and have the wrong coil
& capacitor fitted the breaker points will burn out very quickly. One way round this is of course to fit optical or magnetic electronic ignition
which I'd recommend anyway, it makes a huge improvement.
Between the ignition switch and the starter solenoid I'd put a 30amp relay to keep high currents away from the switch as it will last longer.
Basic diagram would be, but they have left out the relay above -
posted on 27/2/19 at 09:31 AM |
When building my 2.0 Pinto engined MK Indy I fitted all the fuses and relays under the scuttle, behind the dashboard. That way they're kept
away from engine heat and weather (rain). I used a black marker pen to write next to each one what it was for to help me if I needed to check, test
or replace any of them after the build process.
[img][/img]
johnhsmith
posted on 27/2/19 at 05:40 PM |
Premier Wiring do a good Sierra loom for not much money, all fuses etc, good instructions and help available.
Mr Whippy
posted on 28/2/19 at 09:51 AM |
All I would say if doing your own loom is build some slack in it as it's all to easy to make it that little bit too tight and a bother to fit. I
think soft cloth is really the best cover rather than tape as it lets it flex.
James
posted on 28/2/19 at 10:54 AM |
This ^^^^
Dont know price now, mine was £120 when I bought it in about 2003.
You will consider this the best £120 you've ever spent!
- Muhammad Ali
posted on 28/2/19 at 12:17 PM |
Should add I used a Vicky Green wiring loom that was designed for a 7 type car with a Pinto engine.
Not expensive and money very well spent IMHO as it fitted the chassis perfectly and came with a large easy to follow instruction drawing.
If building another car I'd be very very inclined to buy a ready made wiring loom for the car to speed up and simplify the the wiring process.
jps
posted on 28/2/19 at 05:25 PM |
I've got a pdf of the Sierra wiring diagrams if it's any use to you - PM me your email address if you want me to forward it on.
