zx9r ram air
ch1ll1 - 27/5/06 at 06:15 PM
hi all
just went down to my local dyno tuners today,
spoke to them about the car.
they asked what set up it was and when i told them about the sausage filter , he said the they liked the ram (forced air ) effect on them and would be alot better off if i could sort that out
so do i leave it as it is or should i fit a bonnet scoop ( ram air effect ) to help it
not that there's anything wrong with it as it is
cheers paul
JoelP - 27/5/06 at 06:20 PM
you can buy a thing that bolts on inplace of the sausage, which has a funnel of sorts. Its meant to be used to fit a remote air filter, but could be adapted to be an air ram. You would have to work out the filtering still though.
ChrisGamlin - 27/5/06 at 06:22 PM
Ram air has b*gger all effect below about 120mph so absolutely worthless on a BEC.
They may be referring more to just having an airbox on there so you're sucking in cold air rather than warm engine-bay air, which is a benefit although this is often cancelled out by the fact that the airbox is often more restrictive in standard form than a sausage filter. An airbox does have other benefits though, as it also reduces induction noise but if its purely ram air that your tuner is talking about, tell them to get their physics books out, do a few calculations and then come back to you
Hellfire - 27/5/06 at 06:29 PM
As Chris says.
ch1ll1 - 27/5/06 at 06:49 PM
i thought that,
but thought i would ask
then got used to the idea of having a massive vent (blower)
stuck out in the bonnet
DIY Si - 27/5/06 at 07:01 PM
At 150mph you would gain a boost pressure of 0.323psi. So really not worth spending more than 2 mins of your time trying to achieve this.
mark chandler - 27/5/06 at 07:32 PM
Never the less it is very worthwhile ducting cold air to the engine.
An open sausage filter behind a hot radiator is not good !
Regards Mark
DIY Si - 27/5/06 at 07:37 PM
Cold air really is worth the effort. If you can drop the intake temp by 40-45C, which is poss if you change from behind the rad to open cold air, you can get a power increase of up to 12% due to the increased air density. This however assumes the air temp is maintained all the way to the cylinders, so you'd probably only get a 6-9% increase, but it's some of the cheapest power you'll get.
leto - 27/5/06 at 08:29 PM
As far as I understand it the ram effect is not dependent on speed.
http://www.hotrod.com/projectbuild/113_9907_efi/index2.html
You should try to get the effect on the rev. you land on when you change to a higher gear.
ChrisGamlin - 27/5/06 at 08:58 PM
I havent fully read through that article but what I think its actually talking about is tuning the length of the inlet tract to take advantage of what is usually known as pulse tuning. Its not actually talking about ram air (where the airbox is pressurized by the incoming airstream) which most definitely is completely related to speed.
As I understand pulse tuning, the engine sucking air from the airbox causes pressure fluctuation inside the airbox, so one minute the pressure is high, the next its low as its "emptied" and "refilled" (for want of better terminology). Pulse tuning is where you optimise the inlet tract length / volume so that you achieve these high pressures just as the inlet valves of one cylinder open, so it forces a little more air into the cylinder.
[Edited on 27/5/06 by ChrisGamlin]
DIY Si - 28/5/06 at 01:04 AM
As you said, it's about tuning inlet tract length. Which affects pulse wave tuning. As each valve shuts (I think) you get a pressure wave going back up that inlet tract which raises the pressure in the air box. Idealy you want this to coincide with another valve opening so the pressure wave force extar air into this second cylinder. Whilst it does aid power I don't know how affective it actually is, ie I have no figures to hand about it as most of my knowledge of this type of thing comes from a series engines, where you can't really pulse tune anything due to siemes ports. With the older engines it used to be a good idea to get a nice 4-6" inlet manifold, maybe a little more if poss, and don't buy anything with a swan neck in it.
Lippoman - 28/5/06 at 01:54 AM
The positive effect of ram air over the atmospheric pressure is negligible, but are higher than under bonnet where pressures can be lower than atmospheric. So inlet placement may very well be something worth to consider.
"Good" areas for inlet placement on sedan type cars are above the bumper in front of radiator or at the base of the windshield.
Also the effect of "cool" air cannot be stressed enough...
bimbleuk - 28/5/06 at 07:27 AM
You may even find under bonnet pressures higher than atmo! Totally dependant on the front end design but more likely on cars fitted with an under tray or flat panels.
G.Man - 28/5/06 at 10:57 AM
We used to run a ram air dyno at performance techniques for race bikes, the effect of ram air on a bike with a race system is worth about 5bhp on a zx6r, 8 on a zx7r, and 10 bhp on a zx9r... but ram air is not included in bike makers stock bhp figures anyway..
engines technically do not suck air, the cyclinders are filled by the atmospheric pressure being greater than that in the cylinders, so a small increase can make a reasonable difference, but its by no means supercharging...
It actually starts to create a difference in the torque/bhp curve at around 50 mph, depending one how free flowing your air filter si, on the race bikes we didnt run any airfilters, so on those it makes the most difference..
If you make up a plenum to replace the sausage filter and duct it to a scoop then you can create a ram air effect, just make sure you map for it..
ChrisGamlin - 28/5/06 at 11:55 AM
There's a good article here specifically on the Ram Air system of the ZX9, goes into quite a lot of technical stuff and dyno testing etc.
G.Man - 28/5/06 at 03:47 PM
Looks like they were running the stock airbox/filter...
The race fairings give a better inlet tract without all the mesh and multipart pipes etc...
Dunno what fan they used, at PT we had 3, 8 feet fans to generate the wind for the dyno room...
wildchild - 28/5/06 at 05:19 PM
I bet some of them do.
G.Man - 28/5/06 at 09:08 PM
Well every kawasaki we have tested has exceeded quoted figures on the ram air dyno
