Relational CAD
Doug68 - 18/12/06 at 01:01 AM
Hi All,
Thought I'd post this as it shows one of the big benefits (in my opinion) of the good solid modelers like Solid Edge and Solid
Works.
Which is the relational nature of the modeling method if you look at the video you can see that many different parts are being changed just by changing 2 dimensions in a sketch.
Obviously this makes doing the iterations in a design a lot easier than having to do modify one part at a time.
You'll also notice the steel is not cut back at the connections, this is because I asked it not to rather than it not being possible, which it is.
You'll probably need the Techsmith codec to view the video:
http://www.techsmith.com/download/codecs.asp
[Edited on 18/12/06 by Doug68]
Doug68 - 18/12/06 at 01:22 AM
Can't upload the video. Bugger.
Shoved onto YouTube instead.
http://www.youtube.com/watch?v=cqRtoc5vEOQ
Confused but excited. - 18/12/06 at 02:05 AM
It's not on Youtube either.
Doug68 - 18/12/06 at 02:21 AM
Its telling me it may take some time to process.
This was my first go at youtube. So i probably stuffed it up.
It appears to be there now:
tri - 18/12/06 at 02:25 AM
my first time on you tube took a day to upload but 2nd took an hour so you never know how long it'll be
Tri
worX - 18/12/06 at 02:30 AM
it's on there now...
DorsetStrider - 18/12/06 at 05:39 AM
I fecking hate smart arses.
I'm STILL trying to do the bl**dy diagnols!
Doug68 - 18/12/06 at 07:37 AM
I'll take that as a compliment then
Middy Tim - 18/12/06 at 11:44 AM
Constraints and assemblies are wonderful things. They're a pain to start, but they can save your life if you need to change something.
