Atlas LSD oil
mk_xe - 23/3/09 at 09:47 PM
Got a car, not made by me, with an atlas lsd.
Any help would be appreciated, im thinking of changing the lsd oil
How often should i be changing oil and how much does it take.
is there a drain plug or any easy way of checking amount currently in.
Ta
Antnicuk - 23/3/09 at 10:32 PM
I have an LSD atlas. from memory, i takes just over a litre, with the car level just fill it until it comes out of the filler hole which is on the passenger side at the front. I went to burtons who gave me valvoline Durablend 75/90 GL5 LS gear oil. It actually says Limited Slip on the bottle.
britishtrident - 24/3/09 at 08:34 AM
Castrol B373 or Castrol Hypoy LS
Geneally no drain plug on Ford axles to change the oil if the axle is still on the car you need ---
http://www.marinescene.co.uk/product/131/oil-extractor-vacuum-pump
or
http://www.duncanyacht.co.uk/showpartnumber.asp?PartNumberID=223918
[Edited on 24/3/09 by britishtrident]
mk_xe - 24/3/09 at 08:28 PM
thanks
thats great
any idea how oftern the oil should be changed?
NS Dev - 26/3/09 at 08:06 PM
as above in terms of oil and quantity.
As for changes, not really an issue. For a road car I would change the oil when I changed the plate pack, which with "keen" driving of around 4000 miles a year would be once in 2 or 3 years.
All guessed though, nobody really recommends axle oil change intervals other than after a rebuild as things are breaking in.
NS Dev - 26/3/09 at 08:08 PM
ps i also use the durablend but never knew they did an "LS" one. I just added LS additive, only a couple of quid, but will buy the LS version durablend next time!
