Hi guys. Im 24 and picked up an ind-blade last weekend.
I was given a spare diff with the sale. Apparently the car is fitted with a 3.9 sierra open diff and a spare 3.6 diff was included.
Been driving the car this week and the car seems way to low geared for me. top speed seems like about 90..
Yeah sure u can move ur head whilst accelerationg to 60mph
is the 3.6 a slower accelleration or faster ??
PS. its running a 97 blade with standard gear box I pressume !!
Thanks in advance
I say seems like 90 because the anolog speedo goes into speradic mode when I go over 60
cheers
the diff ratio doesnt have as much effect on acceleration as people say, becauce although a 3.9 diff gives more thrust in 1st, the gear runs out
sooner, and then whilst the 3.6 ratio would still be in 1st, the 3.9 diff is now in second gear and has a lot less thrust. Multiplied out over many
gears, im led to believe the difference becomes negligable.
So, id say swap for the 3.6 and see how you like it.
are they easy to change ?? do they need to be filled with somesort of oil ??
cheers Alan
a blade on a 3.92 diff will top out about 110, with a 3.62 it will get to 125 ish, acceleration should be a little slower but may actually improve
in the lower gears due to reduced wheelspin and getting to a higher speed in each gear.
i did this swap on my own car, and what it did speed wise in 6th on a 3.92 was the same as 5th on the 3.62. Car was much better on long
straights/motorways
Rich
cheers Alan
cheers Alan
Swap it over, 1st is very usable on a blade engine with a 3.6 diff and it should just pull max revs in top.
At Brands and Lydden when n/a I maxed the gears easily enough with a 3.6 diff.
Regards Mark
ok...may get to work on it this weekend.. are they simple to do ?? i.e simple nut for nut or is cutting and weldinf required ??
Its easy enough to do I did mine in a afternoon with just undoing bolts bolts and no welding etc
i changed my diff from a 3.92 to a 3.62 and it has better overall performance so a good move
my got the 3.62 and it great top out at about 125mph i think
