ok I'll admit this was my fault, after the Falcon got bashed up (a few years ago) and took it back home, I threw he key into the field in a
temper oops
erm I can't find in it, may have sunk in the mud or the cows might have eaten it
So like, I need a new lock and key...
any one got one going spare???
Plus any ideas about getting the old lock out without destroying my lovely column?? or is it drill time
[Edited on 19/5/08 by Mr Whippy]
I'm looking for one too, the barrel is the same as the mk1 sierra (which I'm using the column of for my Indy), I cannot find one anywhere. I had to drill the centre of the barrel with I think about an 8mm bit then turn it with a screwdriver to the no 1 position and there is a pin a the side that you push in. If you have a similar old ford key that is worn, it will open the lock with a bit of wobbling around and the like, once you get it out you can get a proper key cut using the number on the side of the barrell.
