7" Ford Escort/Sierra Cosworth LSD Diff 3.62
silky16v - 21/10/13 at 12:41 PM
Ford Escort/Sierra Cosworth 7" 3.62 LSD Diff
surplus to requirement now I've sold my MNR
£150 + P&P (£15.00) or arrange you own collection or collect in person (north west cumbria)
[Edited on 22/10/13 by silky16v]
bi22le - 21/10/13 at 03:36 PM
So thats bold on shafts, right?
loggyboy - 21/10/13 at 03:45 PM
Photos certinaly show the bolt on stubs.
40inches - 21/10/13 at 05:28 PM
Isn't the diff itself splined, and if you pull off the bolt on stub, you can use push in shafts?
doobrychat - 21/10/13 at 05:46 PM
Only on Open diffs not LSD's or that what i was told when i got a LSD for mine..
silky16v - 22/10/13 at 10:33 PM
Bolt on shafts yes
mcerd1 - 23/10/13 at 09:38 AM
no you have to use bolt on shafts with ford LSD's
this diff should have the flanges for the 100mm CV joints
(suits all models except the sierra cossie 2wd which has 108mm CV's)
[Edited on 23/10/2013 by mcerd1]
silky16v - 23/10/13 at 09:55 AM
yep as above all correct i measured the flanges last night
scimjim - 23/10/13 at 09:56 AM
It's a fairly simple job to convert push in shafts to bolt on though.
silky16v - 28/10/13 at 11:03 AM
Bump!
silky16v - 2/12/13 at 09:27 PM
Bump!!!
silky16v - 3/1/14 at 01:21 PM
Bump!!! Try again for the new year
baz-R - 5/1/14 at 11:46 AM
any more info on this?
scimjim - 5/1/14 at 12:20 PM
http://www.locostbuilders.co.uk/viewthread.php?tid=187618 check shaft dia and number of splines first though.
