Kitcar engine package
richard munnis - 17/1/17 at 06:13 PM
Hi folks Just testing the water thinking of changing to BEC
Engine as follows
2.0 crate Blacktop zetec proper raceline sump steel lightened flywheel ford pinto clutch setup starter running nodiz brain with zxr9 carbs reverse water pump and alternator
Gearbox 5 speed type 9 quaife gearbox straight cut gears with alloy bellhousing rebuilt this year only used for about 50 miles since 4 branch stainless steel exhaust
May split if have enough interest
Cheers Richard
Thanks for looking
Price and spec further down the listing cheers
[Edited on 18/1/17 by richard munnis]
slingshot2000 - 17/1/17 at 06:24 PM
Any idea of prices? Plus location ?
roohunter - 17/1/17 at 09:57 PM
What sort of power ? Fancy a straight swap for a zx,9
Yorkie - 18/1/17 at 07:59 AM
u2u sent.
Yorkie
richard munnis - 18/1/17 at 09:40 AM
Will sort out price tonight would rather sell complete or in two lots as follows
Engine package complete with sump starter nodiz brian etc
Type 9 quaife 5 speed gearbox with alloy bellhousing
Thanks for looking
Richard
richard munnis - 18/1/17 at 09:46 AM
Would also do a deal for a cbr1000 package 2007 onwards
Cheers Richard
Yorkie - 18/1/17 at 11:07 AM
Thanks Richard
I would be looking at the complete package.
richard munnis - 18/1/17 at 08:11 PM
2.0 blacktop zetec crate bought engine
Raceline alloy sump cost nearly 600 alone
Retro ford steel flywheel drilled to suit pinto clutch super light
Danst Inlet manifold and zx9r carbs including setup kn filters
Nodiz brain and wiring loom
Stainless steel exhaust system
Reverse water pump
Alternator and brackets including mounting brackets
5 speed type 9 quaife gearbox straight cut gearbox rebuilt this year including alloy bellhousing and quaife quick shifter stick and rs2000 clutch lever
I am sure I have missed a few other pieces but will be sold ready to run
Price 2500 no offers
Just drop it in and away you go the gearbox new would cost this alone
Can put on a pallet for collection as I am in North. Ireland shipping should be about 90 pounds using landbridue haulage
Yorkie - 18/1/17 at 09:31 PM
u2u sent.
Cheers Yorkie.
