Front top Wishbones
Macca - 29/1/06 at 10:58 AM
Due to a change from sierra to cortina hubs I need a pair of top wishbones for a book chassis.
My original ones had a larger thread to suit the rose joint for the top mount on the hub!
Col
ned - 29/1/06 at 03:09 PM
Col,
I have a pair of lolocost book top wishbones that I'm no longer using.
They could do with rubbing back and a lick of paint. they have bushes and crush tubes with them if they're of any use to you.
Any good?
Ned.
Peteff - 29/1/06 at 03:35 PM
Lolocost use M10 bolts don't they Ned, what size joints were you using and how wide are your chassis brackets? Didn't you use a Transit M18 top joint thread, not many rose joints are bigger than that.
ned - 29/1/06 at 10:33 PM
yup, m10 pete.
Ned.
