Finally managed to get hold of the spoiler I wanted... Now do I keep the end curves...or chop them off, bad photoshop included! Opinions wanted on
what others think. If I chop the curves off obviously the spoiler wouldn't be as wide so not sure it would look right, hard to judge
With that spoiler I would keep the end plates on. If you want one without end plates I would personally go for one like the noble m12, more gt3 racer
look than street cruiser.
[Edited on 15/11/14 by Ugg10]
Quite like the end curves
keep the curves imo it looks far better with than without
^^^ ditto
I am not a spoiler fan, but with the ends, appear to follow the curvy likes of your car, so keep them
with out the ends, it looks like you have bought a halfords one and stuck it on
just imho !
steve
Keep the ends - fits well with the car
Better with the ends for my eye - blends better with the bodyshell, without it looks too short.
I like the middle bit following the contours of the car but the ends look a bit too max power... Chop them off and extend the wing to full width and put little vertical winglets to finish the ends. Imho
keep it curvy
What about lowering it a bit and blending the curved ends into the rear wings.
Keep the ends and loose those god awful headlights!!!
No, headlights I said!!! Why not put them behind an acrylic cover if you realy want that type of light. I just think it destroys the front end look. I admit my idea would make it look a bit GT40ish but nought wrong there. Just my opinion though marra!
You might have IVA problem with front position lights. I presume they are in one of the headlights. They must be visible from an angle of 80 degrees to the side of the car. The lights shown do not look compliant. You might have to add an actual front position lamp (sidelights) to get through.
