Hi All,
My car build is on the home straight now.... 😊, I wonder if anyone could help, I’m after some IVA compliant slim LED rear lights, any
suggestions would be greatly appreciated.
Kind Regards
SVC , Carbuilders solutions ,possibly Europa car parts may be able to help?
May be something here? Bolt on Bits or HERE
They are US based but https://www.customdynamics.com/ always have pretty cool stuff, albeit not cheap.
Dont worry about E marks, as long as they look and function as a 'normal' E marked light would then they are fine for IVA/MOT.
Its only the Fog that needs the E mark (with F or B also) for IVA.
I bought these.
https://www.amazon.com/MICTUNING-traseras-resistentes-posici%C3%B3n-camiones/dp/B071FL7VRM/ref=sr_1_14?__mk_es_US=%C3%85M%C3%85%C5%BD%C3%95%C3%91&
crid=2V65T5R9GSUHG&keywords=led+tail+lights&qid=1573866505&sprefix=led+tail%2Caps%2C234&sr=8-14
Apparently, you don´t need them to be approved.
HTH.
AA
LED Autolamps http://www.ledautolamps-uk.com/ even used by RML on the road going Aston Martin Vulcan
I went for all surface mount to avoid having to cut any body work. For reference this is my exact rear setup..
Low-Profile Round Lamp - Combination
EU140STIM
http://www.ledautolamps-uk.com/rear-lamps/compact-combination-lamps/-en57?product_id=121
Square Reverse Lamp (x2)
81WM
http://www.ledautolamps-uk.com/rear-lamps/single-lamps/81-series-square-lamps?product_id=105
Slim-Line Fog Lamp – Surface Bracket
135FME
http://www.ledautolamps-uk.com/index.php?route=product/product&product_id=175&search=fog
High Mount Stop Lamp
235RHM12E
http://www.ledautolamps-uk.com/index.php?route=product/product&path=59_77_319&product_id=62
Single Surface Mounting Bracket – White
235W1B
http://www.ledautolamps-uk.com/index.php?route=product/product&product_id=334&search=235
Licence Plate Lamps 60 Series
https://ledautolamps.com/licence-plate-lamps/286-41-series.html
I have just ordered a pair of their HL146 Series Headlamps
https://ledautolamps.com/products/545-hl146-as.html?search_query=headlight&results=15
[Edited on 19/11/19 by atomic]
Thanks guys for all your replies
