Here we have a 1995 Astra turbo diesel.
Can you guess what locost project this is being turned into??
[Edited on 6/11/08 by ragindave]
A self propelled trailer?
A Gonig ?
Not sure but the seat looks comfy.
As a mobile car battery charger?
Lawnmower?
since its a diesel could be a -
£6 worth of scrap?
You've got me there!
I was trying to think of something witty, but the words 1995, Astra and Diesel have confounded me
What's in the sack, its giblets?
ahh so you have been inspired?
don't you just wish you'd told us???
Keep guessing
No. I've still no idea. It's like you've attached it to some bits of tube. A bit like if you were building a kit car but a diesel one. And that's just crazy.
Rear-engined seven-ish sort of car?
Probably something to tow his kit car?
a powered wheelbarrow ??
something like this?
Well if it's diesel he's got to be making some kind of farm vehicle, and will run it on pink diesel
a seven with a diesel powered seat heater?? - just put some holes in the back of your seats
more seriously - looks neat, but please enlighten us!
Still very cold I am not building this but a friend of mine is.
Big clue this one
Diesel powered Parts Washer (heavy duty) ?
a torquey trike
So we are looking at the back of it, and those tubes are wheelie bars then?
Mike
A pinto lump mover?
a two wheeled, motor-unicycle?
Is your '' friend'' gonna wear a set of tattoos and grow a long beard and wear a leather jacket with a Hells Angel insignia on his
back when he ''drives'' it ?
I've got it, it's a Diesel powered rickshaw!
Yes?
Very very Hot still not quite right.
Here we go the answer....
A moto Pike and side carp
Love it.
Don't want one , but I love it.
Yet another proper bloke in a shed, not a poncy kit car builder.....
No it is not Santa on his new sleigh
No not tooooo keen on that. It's the engine you see. The trouble with that engine is that the valves pocket and eventually you won't be able
to cold start it. Mind you, you can sort of cure it, but you have to re-shim the valves every 20k.
My next project.
A Jag powered on of them
Originally posted by jollygreengiant
No not tooooo keen on that. It's the engine you see. The trouble with that engine is that the valves pocket and eventually you won't be able to cold start it. Mind you, you can sort of cure it, but you have to re-shim the valves every 20k.![]()
your friend is a mad, mad man.
seems like an awful lots of fuss and bother, why not stick with the traditional design.
just kidding
Seriously, will that actually go round corners with no wheel in line in any way with any other wheel?
The front is yet to be re worked it will have centre hub steering when it is finished castor and camber adjustment so it can be tracked properly
I love it really! Especially if you keep those colours.
Have one question though. Bearing in mind I know absolutely nothing about bike-and-sidecar dynamics - why all the effort for the one-wheel drive
conversion and the bespoke nearside suspension, rather than leaving the donor's suspension both sides and 2 wheel drive?
Liam
Wow Mr Whippy that pic of a blue shed u posted looks like a cross between an Africar and an err Africar. To keep it concour and original it should
really be coated in orange epoxy.
Surely he ain't going to put the gearchange there? It would act as a sort of abs system cos u'd soon let go of the brake lever after
sliding forward and hitting the gear lever.
That's going to a bundle of fun round corners!!! It'll drive like a f1 car when one of the front wheels falls off!!!!
What exactly is it?
Is it a trike or a motorcycle with powered sidecar?
I recommend you/he do the research first because I am pretty sure the motorcycles with powered side car are no longer legal on UK roads.
I'd be interested to see the gear linkage on that vehicle, Vauxhalls are usually rod change, and although it enters the grearbox at the top, it
faces the wrong way
John
Originally posted by 02GF74
What exactly is it?
Powered sidecars may not be legal, but there's no reason why the sidecar can't carry the engine, leaves more room on the bike for
passengers
Simon
Sorry, forget how legal it might be - how does this layout work in a going round corners type way? - or have I misinterpreted the pictures?
Apologies for the large picture btw
[Edited on 8/11/08 by D Beddows]
It is finished take a look at this
http://www.sidecar.freeuk.com/gallerybaker.htm
awesome!
How did I miss this thread before??? It's the funniest one I've ever read!
Is your mate Terry Pratchett?
