Hi All,
I have an oil leak from where the Distributor goes to the Cam, I have tried Ford but they will only sell me 5 seals at £45, any ideas where I could
get a single seal?
The engine is a 2.0 ltr DOHC circa 1992 out of a Sierra.
Thanks for your help.
Bob
A local motor factor will probably sell you a top end gasket set for less then £20 with all the seals and gaskets you need for the engine.
Alternatively try Burton Power who should be able to supply the kit or individual seals you need.
http://cgi.ebay.co.uk/FORD-2-0L-DOHC-8V-HEAD-GASKET-SET-VDT-481-2_W0QQitemZ200226303005QQihZ010QQcategoryZ21654QQcmdZViewItemQQ_trksidZp1742.m153
.l1262
Gaskets for Classics on ebay is always a good bet
IIRC the timing chain tensioner is a use once item that needs replacing when the head is removed , in fact the chain itself may have to be replaced as well . Doesn't appear to be tensioner or chain in that set. It has been a while since I last worked on one so I could well be wrong?
