Hadn't had a chance to weigh the "new" Furore b4 SVA & was somewhat pleasantly surprised to discover it's unladen weight was
just 452Kg!!! & that's with the larger fuel tank (full for SVA) & the Toyota 4 AGE engine & box which is hardly the lightest thing
around being cast iron block. My aim had been for around 525-550kg with a car engine so I'm well pleased & adding a front wing,rear wing
element & a couple of fire extinguishers isn't going to add more than about 10-15kg.
The bike engined version will therefore come in at around 375kg, which has got me scratching my head a bit as I can't work out why it's so
light, the chassis weighs about 75kg it's got a standard 063 battery & they're not exactly little lightweight wheels & tyres! I
believe that's around the same weight as the Roadrunner Sprint which is of course a single seat & using the very light R1 engine? can anyone
confirm?
So what do yours weigh is anyone sub 400kg & if so how have you got there? Particularly anything mid engined?
my beach buggy is over 600kg!
Was that 452kgs the weight of the car at the sva centre,as these weights are usually achieved by weighing the front and rear axle independently,then adding them together,its not very accurate,for example my 1st Indy weighed 440kgs at sva,its actual weight was 480kgs.So if this was the case you may find your car weighs nearer 500kgs.
Mine has to be less than 350kgs for the regs
I'd agree with Paul. If you had it weighed at SVA, unless you specifically asked for the vehicle weight, then the front and rear axles would be
weighed separately.
Better to get it weighed independently on accurate scales.
Phil
Our blade engined Indy had an axle 1 weight of 194kg and axle 2 weight of 220kg. The actual weight of the vehicle was nearer 500kg.
[Edited on 6-1-09 by Hellfire]
My car was weighed on a single small weighbridge at SVA, a portly 700kgs fully wet!
Just glad I have twin 19" widescreen monitors
My locost was exactly 600kg when weighed at a local weighbridge - that's with a full tank, all the usual fluids, tool roll in the boot, etc.
My GTS is 625kg with a full tank etc
Just glad I have twin 19" widescreen monitors![]()
Love the grasser bet it's not that clean now though
