has this happened to you???
nib1980 - 11/4/09 at 05:13 PM
Hi All
Went outside today to work on a small gasket issue on the exhaust, and some how, I've now gone to an engine out and new sump needed
see thread http://www.locostbuilders.co.uk/viewthread.php?tid=110758&page=1#pid924411
How many times has this happened to you?
many thanks
DIY Si - 11/4/09 at 06:20 PM
Sounds a bit like me and my car. It's always had a slight knock, which I put down to being a BEC. One day it started to get worse, and I started getting more false neutrals. Then I realised it was 4th gear going south. Only thing is it went away fully on a run out to a TVR meet, and I was already 45 miles from home. Decided to carry on, and made it nearly all the way home just missing 4th. Got 3 miles from home when all the drive went. I assumed a bit of 4th gear had jammed the clutch. Turns out the prop centre joint had stripped ALL it's splines out. So now I had no 4th and needed a new prop. Thanks to malc though it's cost me less than £500 to get a whole new gear set, selector forks, new TRT prop (and mine wasn't before) and reseal the engine. Just got to see if it works now.
omega0684 - 11/4/09 at 06:23 PM
just the excuse to give the misses as to why you are about to spend several hundred pounds on a dry sump system
A1 - 12/4/09 at 12:33 AM
sounds familiar...went out today to try fixing dads car, ended up wiring in the fan, cutting some new vents in the bonnet and putting in a wee deflector...
good luck fixing it up
LBMEFM - 12/4/09 at 05:41 AM
Does your dad wee on the car often then to need a deflector?
rusty nuts - 12/4/09 at 08:17 AM
You will be old one day!
A1 - 12/4/09 at 04:00 PM
nooo! a 'wee' as in small deflector...although its actually kinda big
haha!
