Are these any good? Are the IVA Ok?
It says they just "push in" to a 6.5mm hole is this secure enough?
Also where on the chassis does everyone attach there brake lines? the only place i can see to do it is right down on the lowest chassis rail, but this
seems to low? Any pics of how other have done it?
Mikkel
They'd better be
My understanding is they are what 'real' car manufacturers use so should be fine.
i used singular ones of yjose for brake pipes but p-clips for fuel lines
http://cgi.ebay.co.uk/STAINLESS-STEEL-%27P%27-CLIPS-6.MM-%2f-1%2f4%22_W0QQitemZ280334506296QQcmdZViewItem
these are a lot better,have a punt round and you may get them cheaper,you will need a lot of them,dont forget wiring loom and fuel pipes
I put mine on a strip of alloy rivited to the centre uprights see my photos
The same clips are a bit cheaper from here,11 clips for £7.49.
http://www.bresco.com/acatalog/Plastic_Pipe_Clips.html
I used similar clips in several places on my car - they're very secure.
