Ok had a good day sorting out the garage so i could do some work today on the locust ive manged to strip it of the body and when i find my block and
tackle ill have the engine out as that is now going im on the lookout for a 2.0 mondeo to strip off all the parts i need any way the day started like
this
then take a few bits off and it looks abit like this...
then take one big bit off and it now looks like this ...
Im going to be replicating the old wooden body for a steel frame and aluminium sheeted body i'll start making the jig in the week, when the other
half goes on holiday so i can spend extra time on my new toy, cheers steve!
where's the chassis?
[Edited on 21/6/09 by omega0684]
If you keep the same chassis and build on say a bolt on space frame to take aluminium panels will that mean you do not need to IVA it as it will have
the same chassis. If you start with a complete new chassis it will be a new amateur built car.
You may need to keep the engine and a few other bits to not have to re test it?
I could be miles off
Adrian
hmm.... Now that chassis is ASKING for a nice light body ontop....
Would be a fantastic platform to build an old school racer rep... or mini cibra type thing...
Will an ali body be strong enough with that narrow chassis?
Depends how you build the body!
I would be inclined to weld some lightweight box section outriggers either side of the backbone to support the outboard edges of the body.... exactly
like every TVR...
personally I'd not bother and just finish it for the road. May not handle quite as good as a spaceframe car but its not a world away from my JBA Falcon, chassis design wise and that’s a blast to drive.
I'd personally want something stronger than plywood protecting me from side impacts......
I would be inclined to weld some lightweight box section outriggers either side of the backbone to support the outboard edges of the body.... exactly like every TVR...
the car has never been i/sva'd so it will need doing when shes finished, basically yes i will be making a spaceframe to put on top of this, in my head its easy to explain, its harder in words its will be steel box with aluminium sheets for the sides and floors etc. i want to practice on this kit car and if it all goes well i will build one from the ground up, like the book cars, cheers steve!
