... my engine is f**ked.
took the plugs out, turned it over - turned over easily, no fountains of water out the plug holes.
fitted plugs, wired up leads and started it up.
no nasty noises, running smoothly too, hmmmmm looked promising..
...... but after 2 mins, see steam coming out of exhaust and from juncture of central two exhausts ...
Oh well, look like a head off job.
question remains as to why it overheated in the first place?
At the risk of stating the obvious, it is not condensation from water produced from combustion. I thought the headgasket had gone on my first start,
it was just because it was very cold.
If it is the head gasket have you looked at thoses head seal fluids. My neighbour owns a garage and he has seen that stuff work, (on a jeep) about 2
years plus still working.
Darren
bad times
think my bmws engine is going the same way. it was a cold night the other night, but lots of steam out the exhaust when it was at full temperature.
also took about 2 litres of coolant. and the system was olny refilled a few weeks ago
I have a Mexico head if yours is fooked - You can have it FOC just sick of seeing it TBH lol
Was the engine known to be good ? Did it have the pipe from the inlet manifold connected to the water pump? Did the thermostat have a small bleed hole ? Chances are when the engine was installed it had a blown gasket or it had an airlock behind the thermostat. I always removed the thermostat housing when filling mine until the water level was at the top of the head surface before refitting the thermostat and housing but recently fitted a bleed valve in the manifold to pump pipe. Does your car have an electric fan? Is it working?
told by seller it was good. I stripped it down and reassembled it with some improved bits e.g. duplex vernier timing gear, big valve head, steel post rocker gear, BCF2 cam
yes, as per original 1300.
No, brand new 'stat but I drilled 4 mm hole, so yes. 'stat not tested.
Yes, fan works, in fact it was running more than it should have been
Originally posted by turbodisplay
At the risk of stating the obvious, it is not condensation from water produced from combustion. I thought the headgasket had gone on my first start, it was just because it was very cold.
If it is the head gasket have you looked at thoses head seal fluids. My neighbour owns a garage and he has seen that stuff work, (on a jeep) about 2 years plus still working.
Darren
I have known a Xflow head to crack between an inlet and exhaust valve seat on a cylinder, leading to water in the exhaust. (personal experience)
^^^^ thanks, youo've really cheered me up.
Favourite place is the very thin bit between cylinders 2 & 3, usually caused by careless torquing down...
...but you probably didn't want to hear that either.
